Lugnuts keep coming loose
Old Apr 14, 2012 | 03:29 AM
sawfiler's Avatar
sawfiler
I have a 2009 x coupe with stock 18 rims on it. I just put them back on the car after changing the winter rims and the lug nuts will not stay tight. Do I need to drive the car a bit to have the rims seat properly on the hub and then retorque?
I am worried that I mat loose a wheel or damage something. I can torque them to 80 lbs and then recheck them a day later and some will be loose?
Any ideas? The lugs are stock also.
Old Apr 14, 2012 | 03:47 AM
ShyAznB8oi's Avatar
ShyAznB8oi
strip studs maybe??
do you torque your wheels off the floor or on the floor?
Old Apr 14, 2012 | 08:24 AM
mtrsprt's Avatar
mtrsprt
If you are truly torqing them to 80ft-lbs, using the right lug nuts, and making sure both mating surfaces are clean of dirt/debris, then they should not be coming loose, unless they are stripped, or not seated all the way somehow.
Old Apr 14, 2012 | 08:28 AM
breftayka's Avatar
breftayka
Make sure the wheel is flat against the hub before you lower it to the ground and tighten the lugs all the way. I tighter the lug nuts as much as I can before lowering, and then tighten or torque if I have a torque wrench available.
You aren't using spacers right?
ill12will8
Oct 26, 2015 10:09 PM
New2Infinity
Sep 9, 2015 10:34 AM
xpcgamer
Sep 7, 2015 07:10 PM
