Will this fit?!
Old Jan 8, 2012 | 02:28 AM
mrxtien's Avatar
mrxtien
Will this fit?!
i have an 09 sedan journey. want to get wheels but not to knowledgeable with specs.
Specs are: 20x9.0 +16 O-disk and 20x10.5 +19 O-disk; 5x114.3.
would that fit?
and im assuming that O-disk is has something to do with brakes. how do i know what mines are?
Old Jan 8, 2012 | 09:54 AM
EnviedG35's Avatar
EnviedG35
No....if you are at stock height....both front and rear wheels will stick out wayyy past the fenders. Even with a mild drop, like from Eibach...the fronts would fit with some - camber, but the rears would need some tires with a good stretch and run a good amount of - camber. With an more aggressive drop, say from a set of coilovers....you could fit the rears with a good stretch, from maybe a 255, 265 rear tire. and good amount of - camber. Simple answer you your question, No...these wheels will not be a plug and plug set and are pretty aggressive for sedans.
Old Jan 8, 2012 | 11:22 AM
I think offsets in the 35-40 range are about stock.
Old Jan 8, 2012 | 06:16 PM
mrxtien's Avatar
mrxtien
on the same 09 sedan which has a better and a smoother ride. coil overs or springs?
Old Jan 8, 2012 | 10:07 PM
If budget isn't a concern coilovers are the clear winner since they're adjustable and some have different control (firmness) settings. They also won't overwork the shock like lowering springs do w/ stock strut/shocks.
You can get a decent ride w/ lowering springs but coilovers are definitely a step up.
Old Jan 8, 2012 | 11:31 PM
mrxtien's Avatar
mrxtien
thanks a lot.
37
Oct 17, 2020 11:12 AM
BurtoN86
Nov 3, 2015 04:40 PM
ck1109
Oct 15, 2015 11:06 PM
2K1 6T8
Oct 6, 2015 07:40 PM
si_driver
Sep 30, 2015 11:46 AM
