Do vossens make you slow?
Old May 21, 2011 | 01:34 PM
Peyman's Avatar
Peyman
when i got my volks, i was runnin 255/40/19 in front and 275/40/19 in rear, i felt the car got slower, i changed the front tires to 225/40/19 and rear to 255/40/19 and problem was solved...
Old May 21, 2011 | 06:13 PM
coolraz's Avatar
coolraz
Yeah that makes sense, you reduced the overall diameter of the wheel. Your first set was same diameter as stock and then your second set was smaller. On the 20's, I don't know if I can do that because there is not that much rubber as it is, i'm afraid 255 in Rear (which would be the equivalent of your downgrade) would be so thin that even little potholes will damage the wheel. Is there anyone running 20x10.5 with 255??
Old May 21, 2011 | 07:21 PM
ECain18's Avatar
ECain18
You also went from 18" wheels to 20" wheels. From my understanding, you should improve top end speed, but lose some acceleration from that conversion. It would be like if you lowered your gears in your rear diff. You would go faster, it would just take longer to get there. That, coupled with the weight from the vossens, hurts your acceleration.
Old May 21, 2011 | 07:29 PM
coolraz's Avatar
coolraz
That makes sense actually I do feel it faster when I'm passing people (on the same stretch of road driving to work I'm actually passing them in higher gear dont feel the need to downshift like I used to). What would be some things you could do to re-gain some acceleration?
Last edited by coolraz; May 21, 2011 at 08:07 PM. Reason: Noon question deleted : )
Old May 21, 2011 | 07:47 PM
ipitythefoo's Avatar
ipitythefoo
Main reason why I do not want Vossens is because they are damn heavy.
Old May 21, 2011 | 08:05 PM
FM37's Avatar
FM37
Im running Vossen 086s 10.5 on Falken 255s.
I took a rear off my car and weighed it today. With air/tire/rim = 61 lbs.
Anyone know how much the stock 19s weigh with tires/air?
Old May 21, 2011 | 08:07 PM
FM37's Avatar
FM37
^ Im running 20x10.5 with 255/30/20 in rears. I hit a pothole the other day...i was only doing 10-15mph but nothing was damaged.
Old May 21, 2011 | 09:00 PM
coolraz's Avatar
coolraz
Dunno about the 19s but the 18s with tire and air is 49lbs (just weighed mine). so I gained at least 24lbs in the rear and probably about 18 or so (since it's 20x9.0) in the front. On top of that my tires are bigger.....I can definitely see how it would get slower...
Well see how the tune improves the acceleration.
I was driving behind a TT g37 that thing pulled like a monster....FI is starting to be very temptn lol
Old May 21, 2011 | 09:19 PM
FM37's Avatar
FM37
wow 49lbs for the 18s. I'm dying to know how much the 19s weigh. Some1 still with their 19 inch stockers please weigh them!
Old May 21, 2011 | 10:01 PM
nowayg37's Avatar
nowayg37
OEM 19" 10 spoke G37 Sport wheels & tires
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Old May 21, 2011 | 10:07 PM
MACS's Avatar
MACS
I absolutely understand that going from 18x7.5 fr and 18x8.5 rr to 20x9 all around I am gaining weight. But I am not tracking my car. Sure, I like driving fast. Love the handling, too.
But... since I am not racing 1/4 miles... I'll take style over function.
Old May 21, 2011 | 10:09 PM
symple84's Avatar
symple84
A thread like this makes me happy that I have Advans....I had Vossen 086 and they are very heavy but then again they are a solid one piece cast wheel
Old May 21, 2011 | 10:30 PM
Doggy's Avatar
Doggy
Honestly though does it matter that much? I got cv1s and didn't notice ****
From stock, I'm running -3.4 camber on a stretch setup and didn't notice the speed
Or ride differ then before at all
Old May 21, 2011 | 10:36 PM
  #29
symple84's Avatar
symple84
I noticed a huge difference when removing the wheels from the car!!
Old May 21, 2011 | 11:02 PM
  #30
ECain18's Avatar
ECain18
yeah i think the 4.08's are for either, i dont see why it wouldnt work with auto
