Vert Tire Wear Question
are your vert rear tires wearing more on the inside of the tire? My tires are wearing alot more on the inside of my stock tires and are almost down to the Cords on the inside. its got 24000k. is this normal or does it need an alignment or camber adjustment of some sort? what is the average life span of these tires?
After having these tires on 3 G's now, i can tell you 24k is a GREAT number to be getting out of these tires.
I got 26kish miles on the OEM tires on my last G and it was getting dangerous
I think he is at 24,000 km not miles. This would equate to approximately 15k miles...
Front or rear?
Stock tires or?
Miles or Kilometers?
Lowered or stock height?
yeah i thought of that.. just got off the phone with the tech at infiniti and he told me once my new tires are on they want to run an alignment because from new till now the springs and suspension will sag a bit but they just gotta bring the camber in a little. Black and silver CV1's just got shipped today from Cali so should be a week before i see them. got Hankook V12's on them, hope these tires serve me well.
Mr. Drop it like it's hot
You can check the manufacturer's wear rating and compare to the stock tires - this should give you some comparative analysis between the 2 and you can extrapolate the differenc between the 2 ratings to determine the approximate additional life expectancy.
FYI - The OEM 19" tires have a 140 rating for tread wear and the Ventus V12's have a 280 rating. This would suggest that (all things considered equally), you can expect to get twice the wear from the Ventus as compared to the Bridgestones.
Bottom line: To ensure maximum tire life - check your tire wear during each 3,000 mile oil change and rotate every other change. And, if you are smart like CVipgo, get an annual alignment.
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
