Opinions on these offsets pls
Old Mar 22, 2011 | 06:28 PM
FireSquirrel540's Avatar
FireSquirrel540
front - 20x8.5 +20
rear - 20x10 +25
My G is not dropped right now. Do you think these wheels will look too agressive/borderline ridiculous? Or will they look decent. I'm going for an agressive look but I don't wanna go overboard.
Old Mar 22, 2011 | 06:29 PM
P Casey's Avatar
P Casey
well what about your tire size?
Old Mar 22, 2011 | 06:35 PM
FireSquirrel540
Unsure about tire size after I order them I going to have a friend help me select the tires (he works at Mr. Tire)
Old Mar 22, 2011 | 06:45 PM
P Casey's Avatar
P Casey
I would recomend lowering ur car it won't look right not lowered.
Old Mar 22, 2011 | 06:47 PM
Kidcane's Avatar
Kidcane
Florida G Club
Yeah they will stick out a bit and look a little strange if you are not lowered. Perfect offset though IMO....if you are lowered.
Old Mar 22, 2011 | 06:55 PM
Slightly aggressive but not stupid like some guys put on their cars.
lsondubz's Avatar
lsondubz
great offsets if lowered.. see if they can shave a few mm off the backpad if you dont plan on lowering
Old Mar 22, 2011 | 06:56 PM
J2S2M's Avatar
J2S2M
You will NEED to be lowered to run those offsets. W/O a drop, they will stick out past your fenders.
Old Mar 22, 2011 | 07:46 PM
P Casey's Avatar
P Casey
Basically what everyone is saying is drop it, if you get eibachs u can run normal sized tires, if u do h-r's or stechs you will need to do a lil stretched tires. Coils u can do whatevr u want.
Old Mar 22, 2011 | 08:32 PM
yogregb's Avatar
yogregb
If you don't want stretched tires, I would recommend offsets closer to 30 and a mild drop...
Old Mar 22, 2011 | 08:51 PM
CleanAsFuhh's Avatar
CleanAsFuhh
Originally Posted by FireSquirrel540
front - 20x8.5 +20
rear - 20x10 +25
I think they will look sick depending what you drop it on.
Old Mar 24, 2011 | 06:30 PM
FireSquirrel540
Would an Eibach pro kit give me a good enough drop to make these offsets look good?
Old Mar 25, 2011 | 02:57 AM
xyz's Avatar
xyz
imo, they'd look great w/ eibach . . .
back might rub a lil . . . unless u go lower or stretch the tires a lil more than 275s . . .
Old Mar 25, 2011 | 04:08 AM
wlmngtn's Avatar
wlmngtn
^^What he said!
Eibachs would look perfect
Old Mar 25, 2011 | 07:40 AM
4drScreamer's Avatar
4drScreamer
Eibachs pro kit would be perfect for those offsets. Just run slightly stretched tires and ur set. Coils would be better, but that's a whole lot more $ and probably need camber kits. Good luck and post pics when you get it all together.
ck1109
Oct 15, 2015 11:06 PM
Kojack
Oct 9, 2015 05:53 PM
bobtaz13
Oct 1, 2015 01:39 PM
VIVID
Sep 27, 2015 09:45 AM
Slapshot1
Sep 27, 2015 08:40 AM
