Flush Offsets
Old Mar 17, 2011 | 09:08 PM
FireSquirrel540's Avatar
FireSquirrel540
Flush Offsets
I bought a set of 18'' aftermarket wheels that look absolutely horrible because I didn't know much about wheels. I want to upgrade to 20 inch wheels but I want them to be as flush as possible with the fenders, no space going in and nothing poking out. Does anyone know an offset spec that will have my wheels flush? I have an 08 coupe BTW.
I want my coupe to basically look like this when its done
Old Mar 17, 2011 | 09:45 PM
It's not an exact science. If you go 9.5" front and 10.5" rear, offsets in the low to mid 30's will be good. In the teens to mid 20's will be too aggressive and stick out. 40's or more may be too inset for you. The best possible scenario is to see the exact wheel on a G37. Ideal is to be able to test fit them on your car.
Old Mar 17, 2011 | 09:52 PM
P Casey's Avatar
P Casey
Also lowering your car have an affect on the way the wheels sit.
Old Mar 17, 2011 | 09:53 PM
P Casey's Avatar
P Casey
Also sometimes the wheels that you like wont have the perfect offsets to make it flush so you might have to sacrafice on one or the other. Brand of wheels or flush look.
Old Mar 17, 2011 | 10:09 PM
FireSquirrel540
Right now I am looking at these set of wheels: 20 x 8.5 / 20 x 10 with +15mm in the front and +35mm in the rear. My coupe isn't lowered at the moment. Would these look pretty decent?
Old Mar 17, 2011 | 10:13 PM
P Casey's Avatar
P Casey
I would lower your car before you get wheels IMO, you dont want to be riding on stilts.
Old Mar 17, 2011 | 10:31 PM
wlmngtn's Avatar
wlmngtn
If you have low offsets without a drop, your wheels will stick out like crazy. Until you drop it, it will sit flush. With a 15 offset in the front, you will need to stretch your tire. Might poke out, but very little. 30 offset in the rear will be nice and flush.
Old Mar 17, 2011 | 10:50 PM
Weiboy718's Avatar
Weiboy718
you're fine with that +15 offset since you're on a 8.5 wide wheel
Old Mar 18, 2011 | 12:20 AM
P Casey's Avatar
P Casey
would that pretty much equal a +20 offset on a 9in
ck1109
Oct 15, 2015 11:06 PM
Kojack
Oct 9, 2015 05:53 PM
bobtaz13
Oct 1, 2015 01:39 PM
VIVID
Sep 27, 2015 09:45 AM
VQCrew
Sep 26, 2015 01:19 PM
