Which offset should I run?
Old Jan 13, 2011 | 03:58 PM
1slowvq37's Avatar
1slowvq37
From: Real Del Mar Baja California Mexico , Chula Vista CA
The wheel size are 19x8.5 F and 19x9.5 R and this are the offset options:
19x8.5F 35offset and 19x9.5R 40 offset
OR
19x8.5F 15 offset and 19x9.5 15offset
which combo will work best for my g37S? going to run 245/40/19 and 275/35/19 , lowered on eibachs.
Thanks!
Old Jan 13, 2011 | 04:12 PM
Doggy's Avatar
Doggy
uhhhhh.... I say stretchhhhhh it
Old Jan 13, 2011 | 04:19 PM
WPPJR30's Avatar
WPPJR30
Stretched tires won't look good with an Eibach drop...
OP, are those the only options?
Old Jan 13, 2011 | 04:24 PM
jhenka's Avatar
jhenka
the first set would be better, 15 will probably stick out, a little to aggressive IMO.
No offense but both setups suck ={ 9.5 on the rear? thats almost stock i would go at least 10-10.5
Old Jan 13, 2011 | 04:31 PM
WPPJR30's Avatar
WPPJR30
This. If you have to choose between those two options, OP, I'd go with the first set-up and maybe run some spacers.
Old Jan 13, 2011 | 08:42 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
+1. You definitely want a staggered setup, and the 15's, there's just no way you can pull that with an eibach drop in the front.
To be safe go option 1, and then have the freedom to space them more if you'd like from there.
Old Jan 14, 2011 | 02:17 AM
1slowvq37's Avatar
1slowvq37
Thanks for all replies I talked to the wheel manufacturer and he said he installed 19x8.5 35 off set for the front and 19x9.5 15 offset on the rear on one of the employees g37, what do you guys think about that combo?
Old Jan 14, 2011 | 02:23 AM
Doggy's Avatar
Doggy
I say 20 all around with 9 inch front, 10.5 rear, 20 in front and 25 rear, but imo opinion id rather get a smaller offset and use spacers to push it out if needed. so maybe ur first setup
Old Jan 20, 2011 | 03:46 PM
Okita240's Avatar
Okita240
I would like to see your 19x8.5 35 off set for the front and 19x9.5 15 for the back setup. I might copy you if it looks good.
Old Jan 20, 2011 | 05:36 PM
jmlenz's Avatar
jmlenz
You can run the more aggressive offsets too with no problems. I say go aggressive! But if thats not your thing, go conservative and like others said...you can always space it out.
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
delfinparis
Nov 16, 2015 02:26 PM
ck1109
Oct 15, 2015 11:06 PM
Kojack
Oct 9, 2015 05:53 PM
bobtaz13
Oct 1, 2015 01:39 PM
