Horseshoe Light On Dash?
Old Oct 9, 2010 | 04:20 PM
Infiniti7's Avatar
Infiniti7
so this light came on about 3 days ago it is an exclamation point inside of what looks like a horseshoe right under the RPM tack. Does anyone know what it is?
Old Oct 9, 2010 | 04:30 PM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
TPMS light. One of ur tires need air.
Old Oct 9, 2010 | 04:35 PM
JohnEnglish's Avatar
JohnEnglish
Page 2-14 of the User Manual
Old Oct 10, 2010 | 01:06 AM
Infiniti7's Avatar
Infiniti7
the light is funny sometimes. it will come on and stay on for a day or so then it will go off and then come back on again. why does it turn on and off?
Old Oct 10, 2010 | 01:23 AM
PureNick's Avatar
PureNick
Changes in tire pressure from a countless number of things. A dealer may/may not try to sell you on nitrogen but I would consider this option if you're constantly having this light go on and off.
I put nitrogen in mine now and air pressure stays rock steady.
Old Oct 10, 2010 | 01:36 AM
JohnEnglish
The air we breathe is 80% nitrogen.
Race cars and airplanes use pure nitrogen for flammability reasons. "Regular air" has oxygen in it and so a pressurized source of oxygen would be a fire hazard, especially in an enclosed space like a landing gear well.
Old Oct 10, 2010 | 01:43 AM
JohnEnglish
One of your TPM is detecting a pressure change significant enough to trigger the light. It may just be a faulty unit. I've had my car for over two years and have never seen it light up.
Old Oct 10, 2010 | 11:36 AM
15951's Avatar
15951
If you put air in the tire to spec and the light goes away, it isn't a faulty unit. Air pressures go down significantly with use (heat = increased pressure) and air temperature (colder overnight = lower air pressure). I've seen them vary as much as 5-6 psi. It's reasonable to assume that the light will go out after you drive on them and the pressure comes up, unless they're more than 5-6 pounds low.
Faulty TMPS sensors are indicated by the low tire pressure warning light flashing for about a minute after the car is started, followed by the light remaining illuminated.
It's important to note that the TPMS means that the tire is significantly underinflated. Not having that light on doesn't mean your tires are at spec pressure, it just means they're not ridiculously low yet.
Old Oct 10, 2010 | 04:41 PM
Infiniti7's Avatar
Infiniti7
i just filled them up yesterday and the light has not came on since. i am here in arizona and it is really hot during the days but the mornings have been in the 70's and thats when the light use to come on compared to 105 during the day. u think that has anything to do with it?
Old Oct 10, 2010 | 04:47 PM
jjkusaf's Avatar
jjkusaf
When I had my G...it would come on the morning during the "winter" .. if that is what you call it here in San Antonio. It would usually turn off during the drive to work. Never did it during the summer times though.
Old Oct 10, 2010 | 07:08 PM
dkmura's Avatar
dkmura
20 Year Member
Tire pressures vary by temperature. As nighttime temperatures drop with the seasonal change you can lose a few psi in your tires.
604gz
Sep 22, 2015 08:42 AM
pcwd
Sep 15, 2015 10:06 PM
B Feelgood
Sep 13, 2015 05:56 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
