Any issue with spacers?
Old Jul 1, 2010 | 07:28 PM
GT35R's Avatar
GT35R
Planning on getting 5 or 10mm spacers and I was wondering if anyone has had any issue with their spacers? Thanks.
Old Jul 1, 2010 | 09:17 PM
vinnys coupe's Avatar
vinnys coupe
Go wider. 15-20 in front 25 rear. I think if you go anymore pending on your drop you can rub not sure. But def go wider. I believe there is something up w the ichiba v1's vibration or something I forget do a search.
Old Jul 1, 2010 | 11:31 PM
GT35R's Avatar
GT35R
Why would I rub if I go wider? I've heard bad stories about ichiba's spacers thats why I made this thread.
Old Jul 2, 2010 | 12:22 AM
Team STILLEN's Avatar
Team STILLEN
We've had a lot of our customers run with H&R spacers vs. Ichiba's.. and do stock them. A cheap and simple upgrade to flush the wheels out, give a wider stance, and H&R does build a quality spacer.
Available in a extended wheel stud (DRS) or bolt on (DRM) configuration for various sizes.
STILLEN : H&R TRAK+ Wheel Spacers
Old Jul 2, 2010 | 01:01 AM
Luke B.E's Avatar
Luke B.E
i got 20mm H&R spacer in the rear. No rubbing and no vibration
Old Jul 2, 2010 | 07:25 AM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Just go aftermarket wheels and get the offsets made to your specs
Old Jul 2, 2010 | 09:11 AM
Kidcane's Avatar
Kidcane
Florida G Club
15-20mm spacers or dont bother. Make sure they are hub centric and you will be fine.
Old Jul 3, 2010 | 05:22 PM
ruckus12251985's Avatar
ruckus12251985
def go with the h&r spacers i haven't had any problems
Old Jul 28, 2010 | 10:14 PM
retrospex's Avatar
retrospex
how wide of spacers should one use for setting the stock wheels flush after a drop on the coupe? specifically the g37x coupe, thanks
Old Jul 28, 2010 | 10:17 PM
hispeed-lowdrag
I THINK 15mm will do it
Old Jul 30, 2010 | 09:51 AM
Only4theGnme's Avatar
Only4theGnme
20mm spacers will rub if dropped on eibach pro srings with a 245F x 275R tire upgrade on stock rims...I don't know if they will work with stock tires
Old Aug 10, 2010 | 11:07 PM
maxipad96's Avatar
maxipad96
Don't do spacers, they vibrate. A 5mm spacer will not be hubcentric. You will have to use the stock hub ring which is not long enough to completely set the wheel. If you are using a spacer you must use a 10+mm spacer that has it's own hub center built in. Then you should be good to go. But spacers still suck.
Old Aug 25, 2010 | 03:45 AM
retrospex's Avatar
retrospex
are you referring to the back/front or both? I wanted to do all four wheels as flush as possible. I'm lowered on the eibachs with the 18" stocks (g37x). thanks
Old Aug 25, 2010 | 08:21 AM
marcelo19lp's Avatar
marcelo19lp
Just do 15mm all around. By the way, since we got this spacer thread. With the 245/40/19 tires and 275/35/19 with eibach drop on the G37S, I know i will not rub. The question is is i put on 15mm all around, will I rub? I'm sure somebody has this set up, your help is greatly appreciate it! Doenst HR and Ichiba2 both have centric rings, why does the ichiba vibrate, while the HR doesnt, thought I ask?
Old Aug 25, 2010 | 09:21 AM
Kidcane's Avatar
Kidcane
Florida G Club
^^Should not have a problem with 15mm spacers. 20mm will rub.
