Offset Gurus please chime in
Old Jan 13, 2010 | 06:54 PM
soolman32's Avatar
soolman32
I will be placing an order for my new set of wheels in the next couple of weeks (hopefully). What are you thoughts on the following wheels specs that were given to me?
20X9.5 +35R 5-114.3
20X10.5 +37O 5-114.3
Will they sit flush?
Thanks for your wise advice
Old Jan 13, 2010 | 06:57 PM
nogoodname's Avatar
nogoodname
that's a good spec... alot of GT30's have those offsets for the G37.
JKashat has or had gt30's with those offsets.... 305 in the rear too
Old Jan 13, 2010 | 07:42 PM
Kidcane's Avatar
Kidcane
Florida G Club
Should sit pretty flush with those offsets. Maybe just a couple mm off.
Old Jan 13, 2010 | 07:48 PM
ReddieG37's Avatar
ReddieG37
those will be safe offsets that will make u sit flush with the fenders with no rub (assuming 245/35 front and 275/30 rear). you can go more aggressive if ud like but will have to run stretched tires and negative camber
Old Jan 13, 2010 | 08:00 PM
VONYC's Avatar
VONYC
i think +25 front and +30 in the rear would sit nice, maybe +35 in the rear would be safe for NO RUB if your going to run like a 285
Old Jan 13, 2010 | 08:03 PM
soolman32's Avatar
soolman32
I appreciate the feedback
I'll most likely keep my current wheel set up:
255/35 F
285/30 R
I'm currently dropped on Tanabe NF210 on all 4 corners but will be switching the front to eibachs. There shouldn't be any issues right?
Old Jan 13, 2010 | 08:27 PM
ReddieG37's Avatar
ReddieG37
It all depends on how much neg camber u want to run. But with that setup, I doubt you will rub.. maybe occassionaly on large bumps and stuff.
I have the same size/offset wheels and 245/35 and 275/30 rears. Dropped on g35 h-techs and the rear did rub slightly every once in a while. I decided to trim the rear fender linings and bumper bracket and no more rubbing issues now
Old Jan 13, 2010 | 08:29 PM
ReddieG37's Avatar
ReddieG37
btw what wheels are u getting? im guessing work wheels?
Old Jan 13, 2010 | 09:50 PM
soolman32's Avatar
soolman32
That's a close guess since Venaci are rebadged Work Gnosis wheels. I m going with the Mesh style with gunmetal face and polished step lip.
Old Jan 13, 2010 | 10:02 PM
Lou@Amplified's Avatar
Lou@Amplified
255/35 F
285/30 R
You'll have to cut a little on the bumper bracket otherwise 285's on the rear will rub unless you get a little more camber. Front will fit nicely.
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
ck1109
Oct 15, 2015 11:06 PM
Kojack
Oct 9, 2015 05:53 PM
bobtaz13
Oct 1, 2015 01:39 PM
VIVID
Sep 27, 2015 09:45 AM
