need some info
Old Sep 4, 2009 | 05:41 PM
last lemming's Avatar
last lemming
need some info
If I don't sell my car, I will be dropping on Eibachs and putting some new wheels (Vossens) and tires on. What I've been trying to determine is what offset / wheel width / tire width is required so that there will be no rubbing onced dropped with proper alignment specs. I am going with 19's probably (but I dont think there are many options with Vossens). I'd like to go 245's front and 275's back, but I'm not sure if 9.5" or 10" inch width should be chosen so there is no rubbing in back, but I'd also like the tire at its outter most edge not to extend beyond the fender edge, and I'd be ok with it being a bit less. I think I'll go 9" on front and I don't think that should be a problem.
Old Sep 4, 2009 | 05:48 PM
jnguyen's Avatar
jnguyen
Eibach isn't a heavy drop man! I use to run that drop and trust me you won't rub. I prefer 20's but 19 will definitely not rub on our car with eibach. I believe vossen will do your offset for you. Go with a 10 in the back I have a 10 in the back right now in 20s and I'm really low and no rubbing.
Old Sep 4, 2009 | 06:10 PM
pfizzle's Avatar
pfizzle
Look up Jarborn1 post he is selling the whole shabang for really cheap.
Old Sep 4, 2009 | 07:04 PM
last lemming
Hey, Joseph, how you liking he sways!?
Old Sep 4, 2009 | 09:42 PM
last lemming
I was also checking out some Axis wheels and I'm wondering about sporting some of these:
or some of these in 20x9 and 20x10:
the car below make me think the ones above would be nice :
Old Sep 5, 2009 | 04:10 PM
Rottten Appples's Avatar
Rottten Appples
VOLKS FTW!! youre not gonna rub dude.. the settings you described are even conservative for a sedan.. trust me I have a sedan and im down on S-techs.. no rubbing here my friend.
Old Sep 5, 2009 | 09:25 PM
last lemming
would this be true for 10 1/2" rears as well with 275's?
Old Sep 7, 2009 | 07:31 PM
Rottten Appples
You could do 10.5" in the rear with a stretched 275.. there might be a tiny bit of rubbing and inner wear with a little more agressive camber.. worse case scenario, you could roll the fender maybe if it was too close, but note that thats my view for the sedan.
37
Oct 17, 2020 11:12 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
BurtoN86
Nov 3, 2015 04:40 PM
BurtoN86
Sep 30, 2015 03:32 AM
VIVID
Sep 27, 2015 09:45 AM
