Tire Help
Old Aug 20, 2009 | 10:06 AM
sbebs2000's Avatar
sbebs2000
Tire Help
I know winter is still a bit away, but I like to have things planned out a little bit and I need some help.
If you install winter tires with tpms can some tire places reset the car so the TPMS will work properly or does it have to be done by the dealer? I live kind of far away from the dealer.
If I buy winter tires without the tpms, I realize the tire pressure warnings will come on, but in the spring if I switch back to the regular tires, do I have to reset anything for the tpms to start working properly again?
Thanks!
Old Aug 20, 2009 | 10:13 AM
nogoodname's Avatar
nogoodname
Thanks!
i bought a winter tire setup from tire rack without tpms. so in winter time i have the light. then in the spring, i put the stock rims on and you do not need to reset the tpms. once it's set, there is no need to reset it unless it stops working for some reason.
any good tire/wheel shop should be able to calibrate it for you. if not, you have to go to the dealer. set it once and you are good to go.
Old Aug 20, 2009 | 10:39 AM
sbebs2000's Avatar
sbebs2000
Thanks for the info!
Old Aug 20, 2009 | 10:40 AM
nogoodname's Avatar
nogoodname
no problem, have any other questions??
Old Aug 20, 2009 | 05:01 PM
sbebs2000's Avatar
sbebs2000
Actually I do now, I just called one of my local tire dealers, a local chain and they said they don't carry and rims that will fit? I thought that was pretty odd since tire rack seems to have a lot to choose from. Do you remember what model of wheel you ordered from them?
Old Aug 24, 2009 | 09:36 PM
anh3's Avatar
anh3
don't do any reset, let the warning light stay on, after I put my OEM rims back on, the car register and the light goes off.
Old Aug 25, 2009 | 07:15 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Agreed, no initilazation needed if using the oem sensors. Once you put them back on in the spring all will be fine.
Check out what winter items we have for your car online here Winter Tire and Wheel Options
Old Aug 26, 2009 | 08:16 AM
sbebs2000's Avatar
sbebs2000
Thanks everybody!
Old Aug 29, 2009 | 08:41 PM
DEC1's Avatar
DEC1
I got my Blizzaks from tire rack...get the 18's with a wheel package. They bolt right on no problem. Just let the TPMS light on for the winter...after a while you don't notice it...too expensive to get the sensors just for the winter. Just check your pressure every few weeks and you'll be fine...but remember don't drive those Blizzaks in warm weather...you'll wear 'em down quick
B Feelgood
Sep 1, 2020 02:50 PM
RYs06MT
Apr 22, 2016 11:00 AM
bri
Nov 23, 2015 11:35 PM
mmnjtwa
Sep 7, 2015 02:27 PM
footballmania32
Sep 4, 2015 03:06 PM
