Official Low Offset/Hellaflush Thread
Old Mar 13, 2017 | 02:30 PM
  #2191
b-drizzy's Avatar
b-drizzy
take a pik of your car to see how the height is
I wouldn't know tbh
I don't have the greatest experience
Originally Posted by douby77
lol na no way the tein is a real low drop. But will the tires tuck in at least and just rims showing. The tein in the rear id's 1.9 btw
Old Apr 18, 2017 | 05:43 PM
  #2192
beezy619's Avatar
beezy619
B-drizzy......are you running front camber arms?
Old Apr 18, 2017 | 06:20 PM
  #2193
b-drizzy's Avatar
b-drizzy
no OEM arms so its at whatever natural camber it gets when have the set up on
Old May 17, 2017 | 02:01 PM
  #2194
denys's Avatar
denys
Need help with tires? Wheel Experts
I traded my work wheels for some Avant Garde F411 3pc wheels.
Offsets
front 19x9.5+12
rear. 19x10.5+18
G37S RWD coupe
im on stance coilovers and camber kit as well
what tires you guys think I can run with this
i was thinking F 245 35 R 255 35 if you have similar offsets that would help if you have pictures I would like to see them thanks ��
Old May 17, 2017 | 07:45 PM
  #2195
beezy619's Avatar
beezy619
b-drizzy....need your help, bro. Couldn't find what offsets you were running up front. Thinking about putting 15mm spacers up front. That would put me at 20x9 +10. Think this will be fine or should I play it safe and go with a 10mm spacer?
Old May 19, 2017 | 01:46 PM
  #2196
b-drizzy's Avatar
b-drizzy
Offsets
front 19x9.5+12
rear. 19x10.5+18
G37S RWD coupe
that sounds like a good tire size you can even get away with a 265 in the rear you should have clearance you have more room then sedan.. post piks when you install, thanks .
What tire size you running again ? and wha'ts the offset on the wheel ?
Old May 19, 2017 | 05:26 PM
  #2197
beezy619's Avatar
beezy619
I'm running a 225/35/20 tire and the current specs of the wheel is 20x9 +25.
Old May 19, 2017 | 05:46 PM
  #2198
MaQG37's Avatar
MaQG37
I'd run a 215 but since you have the tire, might as well give it a shot.
Old May 23, 2017 | 12:51 PM
  #2199
b-drizzy's Avatar
b-drizzy
its a small tire though just becarfull with the dips
id get the 15mm
it'll natural camber itself a bit
Old May 23, 2017 | 05:24 PM
  #2200
beezy619's Avatar
beezy619
I ended up getting the 15mm spacer. Fitment matches the rear now. Just have to be more careful when driving cuz it does rub when hitting dips.
Old May 24, 2017 | 12:20 PM
  #2201
b-drizzy's Avatar
b-drizzy
Awesome great choice,
Yeah I figured it would and well that's how you want it to match tbh fitment got to sit clean on fenders,
Have you got front camber arms ? or you going to
Old May 27, 2017 | 02:03 AM
  #2202
beezy619's Avatar
beezy619
No front camber arms yet. Don't think I need them for the time being. If I do, I think I would with the SPL arms. They look solid.
Old Jul 15, 2017 | 10:38 AM
  #2203
xmajd92's Avatar
xmajd92
Fender rub
hey guys! So I'm lowered on D2 Coilovers and I got some Volk GT-S wheels. Rears are 19x10.5+17 with 275/35 tires. I do not have a camber kit. What would you guys suggest I do here? Pull/roll fenders or should I just add a bit of negative camber here? Check out the pics.
Old Jul 15, 2017 | 11:14 AM
  #2204
Definitely get the rear camber kit, you need to get your toe in spec and no way will that happen without the kit. You're not too crazy back there so camber & a bumper bracket trim should get you there, just be prepared to get tires more often, the price you pay for that fit
Old Jul 15, 2017 | 11:17 AM
  #2205
xmajd92's Avatar
xmajd92
Yeah I was afraid of reading that answer lol. I don't want too much camber so I'll just put my Weds Sports back on and resell them lol.
