Official Low Offset/Hellaflush Thread
Old Feb 23, 2013 | 07:49 AM
  #1756
lilvi3tboyzz's Avatar
lilvi3tboyzz
damn 5.2 neg camber? can i pull it off with -2 or -3?
Old Feb 23, 2013 | 11:04 AM
  #1757
TheGanglyGoon's Avatar
TheGanglyGoon
doubtful my man...
Old Feb 23, 2013 | 11:12 AM
  #1758
P Casey's Avatar
P Casey
one question, if im running 10.5 with 10 in the back 245/35/20 i dont have to pull or roll my fender to not rub right? just need to put neg camberr ight?
If you ran a 245/30 falken you would be fine and able to run about -3. You might even be able to pull it off with a 255/30 falken or Toyo at -3. That's a guess though, but I ran a 275/30 falken on +22 without rubbing. So if you do the math it should work. Neg 3-4 camber is not bad at all, I pretty much ran it the majority if the time.
Old Feb 28, 2013 | 10:56 AM
  #1759
BANNISTER's Avatar
BANNISTER
HELP
any input how much i would need to make this set up work ??? on my coupe and tire size recommendation ??
19x9 -23 High Disk to clear big calipers
(225/35/19)
19x10 -32 Low Disk concave
(255/35/19)
Old Feb 28, 2013 | 11:05 AM
  #1760
fairladyz34's Avatar
fairladyz34
did you already buy them or ?
Old Feb 28, 2013 | 02:56 PM
  #1761
lilvi3tboyzz
if i run 5.2 camber with 245/35/20 will i still rub? or i should be fine with the back?
Old Mar 1, 2013 | 12:54 PM
  #1762
deeznutts23's Avatar
deeznutts23
What disc are you running with this setup? I'm trading in my 35 for a 37 and I've been searching for the right fitment and I believe this is it. You static or on bags too?
Originally Posted by Doggy
Old Mar 1, 2013 | 08:31 PM
  #1763
BANNISTER's Avatar
BANNISTER
staying static ... that fitment is on point i was thinking more
Swangin & Bangin – The Fitted Agency
for more driveability
Old Mar 1, 2013 | 08:42 PM
  #1764
TheGanglyGoon
That black G37 is a full metal widebody on bags, that white G is a full metal widebody on an extremely high spring rate. A stock G37 cannot pull of those sizes at all.
Old Mar 2, 2013 | 10:15 AM
  #1765
BANNISTER's Avatar
BANNISTER
i know there will be some work needed to make these work ..
i went with these sizes instead
its going to be fun
Weds lxz 19x11 -10, 19x12 -6,
Old Mar 15, 2013 | 10:31 PM
  #1766
BL1024's Avatar
BL1024
Fairly aggressive for stockies!
Old Mar 15, 2013 | 11:55 PM
  #1767
IsDatiT's Avatar
IsDatiT
Nevermind
Old Mar 18, 2013 | 10:31 PM
  #1768
xxryanlamboxx's Avatar
xxryanlamboxx
I drive the white SwangAndBang G37 and those offsets you can actually pull off with stock body and slight fender work. You will have to go with a smaller tire. and you will need a lot of camber and stiff spring rates but its doable. I am running something close to those with my setup but i can go more aggressive with my rear wide body. If you have any questions add me on fb. Names ryan lam. facebook.com/yanlamr
HELP
(225/35/19)
(255/35/19)
Old Mar 19, 2013 | 01:21 PM
  #1769
xxryanlamboxx
Recent pic from Import Alliance.
Old Mar 19, 2013 | 01:23 PM
  #1770
xxryanlamboxx
