Nitto Invo Owners Chime In...
Old Jan 22, 2009 | 01:25 PM
Wezbian's Avatar
Wezbian
The toe is within spec, although to the more extreme side of spec. The range is .00 to .20 and im at .15 which seems ok to me. Our cars may not come stock at -1.5 but it is within the stock range. If you look at your rear wheels you can definitly see the camberwhen stock....
Old Jan 22, 2009 | 06:07 PM
finagle69's Avatar
finagle69
ghey thread.
Old Jan 22, 2009 | 09:03 PM
Wezbian's Avatar
Wezbian
So guys, looks like I'm going to run invos up front and neo gens in the rear and have my camber adjusted again by a professional shop...
Old Jan 22, 2009 | 09:04 PM
w0ady's Avatar
w0ady
Originally Posted by ZACHSQUATCH
yeah, may have some toe out.
Our car doesnt come with a -1.5 degree camber stock does it????
toe is what kills tires NOT negative camber like everyone has been saying. change your toe to 0 and your tires will last a lot longer.
Old Jan 22, 2009 | 09:41 PM
WhiteG37S's Avatar
WhiteG37S
I second that.I work at a wheel and tire shop and have seen people blow out tires in less than a month/2k miles and it's always because of the toe.
Old Jan 22, 2009 | 09:46 PM
Wezbian's Avatar
Wezbian
Thanks guys, my only worry is the SPC camber kit wont allow toe to go that far, i may need to buy the stillen toe arm!
Old Jan 22, 2009 | 10:54 PM
HamstersG's Avatar
HamstersG
You should have no problem getting to 0 toe with SPC camber kit (and toe bolts which are part of the kit).
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
G37sPhoton
Oct 4, 2015 11:08 PM
Bennyjoel
Sep 30, 2015 11:56 PM
ajosowiecky
Sep 30, 2015 12:15 PM
