Possible Staggered Setup?
Old Oct 6, 2008 | 08:50 PM
ironchef2008's Avatar
ironchef2008
Hey Guys,
I need the resident experts to weigh in and let me know before I do something wrong! I'm no wizard at offset calculation but here's what I got considering the setup I want to run and the calculator at http://marksink.com/tire_wheel_offset/offset.html:
19x8" Axis Elite with 35mm offset and 245/40/19 tires (2mm extension towards fender with 14mm more clearance from suspension)
20x10 Axis Elite with 50mm offset and 275/30/20 tires (8mm extension towards fender with 18mm less clearance from suspension)
I love the look of staggered wheels but especially the larger diameter rears. Can I do this functionally? Any downsides?
Old Oct 6, 2008 | 09:18 PM
GiGGaplease's Avatar
GiGGaplease
the front would be alright, the rear needs a 15mm to make it sit flush. that would make it +35 all around.
i would go 245/35/19 front; 275/30/20 rear. thats just me though
solo has 20inch front, 21 inch rear. doubt there is anything wrong. you should pm him.
Old Oct 6, 2008 | 09:42 PM
speedracer g37's Avatar
speedracer g37
try this.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Oct 6, 2008 | 10:14 PM
ironchef2008
Thanks for the quick replies. But isn't it not as easy as saying shoot for a 35mm offset for front and rear? Doesn't the 10" width of the rear rim need the greater offset?
I mean as it is, the 20x10" with 50mm offset will stick out 8mm more than stock. Is there really room for an additional 15mm?
Old Oct 6, 2008 | 10:22 PM
GiGGaplease
yes, 35ish offset is what most folks on here got. with +50, i doubt the rear would clear the brakes. my fronts were +50 and it didnt clear the brakes.
Old Oct 7, 2008 | 09:34 AM
Kidcane's Avatar
Kidcane
Florida G Club
Gigga is right believe it or not.....jk. a 10" rear with 50mm offset will be fairly conservative. You can go +35 with a 10.5" rear with little issues so you could go even lower on a 10" wheel.
37
Oct 17, 2020 11:12 AM
jfisher
Apr 25, 2017 01:22 PM
Depravity
Oct 16, 2015 01:37 PM
JC-RH
Sep 27, 2015 09:36 AM
mmnjtwa
Sep 7, 2015 02:27 PM
