Vibration after installing front wheel spacers?
Old Apr 21, 2008 | 01:56 PM
quart's Avatar
quart
I'm not sure if anyone else has had this problem, or even installed spacers, but I did some 5mm spacers up front to slightly push out the front wheels. Around town they seemed fine and car drove fine, but when I took the car on a road trip noticed major vibration from the fronts. I have since taken the spacers off... I used highend H&R spacers which should be true, but don't know.
Anyone else have issues? Of maybe an idea of what I might have done wrong?
Old Apr 21, 2008 | 02:04 PM
Kidcane's Avatar
Kidcane
Florida G Club
I had the same issue from my cheap azz 7mm spacers that were non-hubcentric but now I have 10mm hubcentric and no problem at all.
Old Apr 21, 2008 | 02:28 PM
quart's Avatar
quart
I thought the H&R were hubcentric.... for $85 they should be... I bought both 10mm and 5mm at the same time. 10mm in rear are fine. What brand did you use and on the 10mm, did you use the supplied bolts? Any pictures.... I almost want to say 10mm might be to much, especially on OEM wheels. Are you running OEM 19's or after market?
Just noticed you are a G35... sorry.
Old Apr 21, 2008 | 03:14 PM
SkyzDaL1m1T's Avatar
SkyzDaL1m1T
^^^he switched out the 35 for the 37 from what i have read and seen
Old Apr 21, 2008 | 03:32 PM
Kidcane's Avatar
Kidcane
Florida G Club
Yeah I have a G37 but still in FL G35 Club.
H&R should be hubcentric though so that is kinda weird. Mine are Eibach and I did have to switch out to the longer provided studs and I am on Maya STM's not stockers.
Old Apr 21, 2008 | 03:33 PM
SkyzDaL1m1T
^^^Wanna move out to FLorida damn it lol...
Old Apr 24, 2008 | 04:14 PM
coladin's Avatar
coladin
Exact same problem
Just picked up my car today with Eibach 5mm front and 10mm rear. It looked great and felt alright around town, but once I dot over 50mph the wheel was staring to thrum. By 65, it was undriveable. So I brought it back and they took off the fron spacers and now the car is perfect.
They are guessing, thetech guys at the shop, that the "hub" on the spacer, while hub centric, does not sit as well as the 10mm because the 10mm has more of a hat so to speak. They think that a 10mm spacer should not give a problem but I think I will leave it like this!
My friend says that you can really tell in the rear, a nice improvement, one that I think is a must have.
Old Apr 24, 2008 | 04:40 PM
solopresident's Avatar
solopresident
dont buy spacers!!
Old Apr 24, 2008 | 07:30 PM
quart's Avatar
quart
I do like the way the rears sit now with my 10mm, the best look for the front for me was an 8mm, but no body makes a hub-centric 8mm... there are cheapo's on ebay, but that is it. Obviously our car is slightly different and even the H&R, EiBach, etc are not a tight enough fit.
If they weren't $110, I might try 10mm on the front with the new studs, but that is a lot of work and I think 10mm would be too much.
Old Apr 24, 2008 | 07:33 PM
Kidcane's Avatar
Kidcane
Florida G Club
I found one guy who will custom make any size you want and hub centric. Pretty fair price too. You jkust have to get allot of info on the sizing like centerbore size and a couple other things so he can make it exact.
PM me if you want me to track down his info again.
Old Apr 24, 2008 | 10:56 PM
coladin's Avatar
coladin
I agree, a very wothwhile upgrade to the look because not only does it push out the wheels, but seems to close that wheel gap, it looks slightly lowered.
I think there is space for a 10mm spacer up front, I think I will try it...tomorrow when they install the 275s in the rear and put the 245s up front, we'll put them on and see if they fit right.
Old May 17, 2011 | 10:19 PM
NYCG37's Avatar
NYCG37
I got stock 19' wheels..and recently placed 20" spacers on front (non hubcentric) and every time i drive over 65mph it starts vibrating.... any help ?????
******-SHould i buy Hubcentric ones ????? will this help ?
Old May 17, 2011 | 10:29 PM
You mean 20 mm, and yes. Definitely.
m3clubracer
Sep 11, 2016 09:01 PM
Intake
Dec 25, 2015 09:38 PM
james6980
Oct 9, 2015 01:28 PM
ddayeg37s
Aug 9, 2015 07:10 PM
