TSB - Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Nissan steering lock recall
Old Dec 31, 2020 | 02:16 PM
jxwlhs's Avatar
jxwlhs
Just need to double check before I drop 300 to program a new key--- if a key unlocks and locks a door-- that means the Nissan BCM properly read the code the key transmitted right? Intelligent Key and BCM Troubleshooting
Is there some other different part of the key that receives a signal from the car for ignition/start-button? Even if the receiver of the key itself has no power since I held the key by the start button and inside the receptacle, which should work even with a dead battery, and given that the key code programming is correct since it unlocked the door.
The other case I can think of is if the receiver of the key is broken, then it can still transmit to unlock, but can't recieve the ping from the car to trigger the ignition with a code- is that the right understanding?
Joe27
Feb 7, 2020 08:42 PM
nytxelk
Nov 18, 2019 08:31 AM
blkceaser
Feb 9, 2019 06:14 PM
jdjurado
Feb 6, 2014 05:07 PM
