TSB - Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
ITB12-027 7AT Fix
Old Jun 9, 2015 | 08:01 PM
  #136
G37S-K52's Avatar
G37S-K52
I had mine done at Infiniti of Escondido $140 and I'm happy.
Personally I found the old programming to be too aggressive, it would hold the gear too awkwardly while coasting. Sometimes the transmission would hold third way too long and I would only use DS mode when doing a quick sprint.
With the new programming I can actually drive in DS mode all the time and it's fine, it's still far better than D mode but it no longer holds the gears awkwardly and it seemed to cut down on some of the lag. If you like your G to be at 3500rpm+ while coasting at 40mph then don't do the upgrade... I didn't like that personally, if I want to do that I will use the paddles...
Old Jun 14, 2015 | 01:15 PM
  #137
vollrathian's Avatar
vollrathian
Just had mine done at Infiniti of coconut creek, I feel like the tranny got an exsircism preformed on it. It's a lot smoother now.
Old Jun 14, 2015 | 01:30 PM
  #138
blueis300's Avatar
blueis300
They said they did mine but always seems like its holding a gear to long and cant get it to shift down. Either i get a bog when I get on it or holds the gear to long.
Old Jul 14, 2016 | 07:27 AM
  #139
Alto101's Avatar
Alto101
Sorry to bump an older thread but I just purchased a 2011 Gxs coupe with the 7AT. I have no complaints about the transmission except for the large increase in rpm's when in DS mode under breaking to a stop. I do not know if this TSB has been applied to my car or not but I am guessing it hasn't been. I have an appointment at the dealer this weekend and am thinking about asking about this TSB.
How much does this TSB help with the surge in rpm's in DS mode when braking to a stop? If it gets rid of it; I may just have the TSB applied.
Thanks!
Old Jul 14, 2016 | 09:05 AM
  #140
jsp872's Avatar
jsp872
Thanks!
That's not an issue, it's called Rev matching
Perfectly normal, and it's spikes especially high the quicker you decelerate
So when you come out of a sudden deceleration you have the RPM there help you accelerate faster
The TSB was geared more towards making the shifts quicker in the manual mode.
Old Jul 14, 2016 | 01:47 PM
  #141
Alto101's Avatar
Alto101
Thanks for the info!
Old Nov 27, 2016 | 05:35 PM
  #142
xscoupe1985's Avatar
xscoupe1985
Just got a '12 x coupe. Seems to have the gear searching problem. Which update do I need to ask the dealer for?
Old Dec 2, 2016 | 10:41 AM
  #143
si_driver's Avatar
si_driver
from what I know - there are NO updates for the 2012
Old Dec 2, 2016 | 11:31 AM
  #144
Victory's Avatar
Victory
I have a 13 and was told that they updated my engine and transmission at my most recent service.
Old Dec 2, 2016 | 03:50 PM
  #145
xscoupe1985
I called the dealer and they said the trans is adaptive to driving habits. That sounds like a stupid idea to me. The previous owner must have driven harder than me cuz it acts like it's expecting me to use more throttle in a certain gear and that's why it isn't upshifting when it should. But he said to call back if it doesn't change in a few weeks. He didn't say anything about no updates available. We will see I guess
Old Dec 3, 2016 | 01:11 AM
  #146
Victory's Avatar
Victory
Have you tried rebooting it?
Old Dec 4, 2016 | 11:29 AM
  #147
xscoupe1985
How do you do that?
Old Dec 4, 2016 | 01:02 PM
  #148
Victory's Avatar
Victory
How do you do that?
https://www.myg37.com/forums/d-i-y-installations-modifications/175792-easy-way-to-reset-ecu-without-battery-disconnect.html
Old Dec 4, 2016 | 09:03 PM
  #149
xscoupe1985
I'll have to try it
Old Dec 9, 2016 | 10:41 PM
  #150
Kb Cool's Avatar
Kb Cool
Did they ask you if you wanted it? Personally i like the tranny in my 13. My 2010 was a different story. I hated it and it was updated too!!
