ITB12-027 7AT Fix
#91
Quick search for ITB12-027c found:
http://www.infinitig37.com/TSB/ITB12-027c.pdf
Hope this is right.
Hope this is right.
#92
I got my 2010 G37x back Friday from having this done and I can really tell the difference. Shifts are much smoother and quicker. It makes a big difference in the drivability and its closer to how it's supposed to be.
#93
Hopefully Infiniti issues an update to this bulletin soon and includes these codes. My car has exactly all the symptoms that are described in the bulletin and I'm really frustrated that my codes are not included in the list. It's a shame cause I love my car!!! And it's so frustrating to drive since I'm constantly obsessing on how the transmission feels. I don't know how much of the feeling is psychological. Maybe a lot.
#96
Dose this totally kill DS mode or just soften it up, or what? Also with this help quicken shifts/response in DM mode?
Hesitation/lag when accelerating after coasting is a major issue, I'd really like to have this fix.
Thanks,
JBabsG37
'11 g37 vert
Thanks,
JBabsG37
'11 g37 vert
#101
I just downloaded the pdf of 027d from infinitihelp and it shows:
*2009 – 2011 G37 Sedan and Coupe (V36/CV36) 2009 – 2012 Convertible (HV36)*
This is just like 027c except at the top it states: "This bulletin has been amended to change the first sentence of the IF YOU CONFIRM statement. Discard and previous versions."
#104
I have a 2013 G37S Sedan that I am taking mine to the dealership right now for this (1 hour). I have the sporadic crazy down shift when braking. Also I can't even use the DS Manual mode.......1-2 sec delay between shifts.
#105
They sent a mechanic to drive the car with me sitting passenger explaining how the 7AT learns your driving behavior, and will sometimes do the sporadic downshift at sub-20 MPH speeds.
I insisted that the car should not need to apply engine braking when coasting to a slow stop, and that if I were driving manual, I would never engine brake on a slow stop on a flat road.
They then proposed that perhaps I just need to get used to the way the car behaves as I have never had an automatic before. They will hook it up to the computer next month when I go in for my first oil change......
