TSB - Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
1K Miles Left on Warranty
Old Sep 6, 2011 | 01:44 PM
itisagoodname's Avatar
itisagoodname
So i'm at 59,100 miles on my '08 G37 Sport Coupe. I bought the car used at 32k miles. Standard warranty is up at 60K and power train at 70K.
-Transmission and clutch replaced @ 32k - before purchased
-Rattling exhaust replaced at 32K - before purchased
-Pulsating brakes - TSB performed @ 34k
-Warped gauge cluster cover replaced @ 36k
-Drivers side window auto roll-up (assume its the pinch protection) causing window to roll back down half way - Supposedly fixed @ 36k but still has the issue
-Gas gauge flakey; reads empty/low randomly. - Supposedly fixed @ 36k but still has the issue
Also noticed some dark fluid running down and caked on my rear diff... any ideas? Think i read somewhere it was a fluid filled bushing but im not sure.
From those who have put on more miles than I, what else is there to look out for that would be covered under the basic warranty? I ride my motorcycle everyday so i really only drive my car once a week or so right now.
Old Sep 6, 2011 | 02:22 PM
harbin9er's Avatar
harbin9er
whoa
sounds like this car was abused by first owner
"Transmission and clutch replaced @ 32k" :S
Old Sep 6, 2011 | 02:38 PM
itisagoodname
Throwout bearing issue most likely and was all replaced under warranty. Its always nice to know that there's a fresh transmission and clutch when buying a used car... but knowing that it HAD to be replaced still bothers me a bit.
Old Sep 6, 2011 | 04:13 PM
Frankyg37s's Avatar
Frankyg37s
omg i had all the same problem as you(exept oil on diff and gas gauge) and even now when i auto roll up window it comes back down 1/4 really anoying,i have 42k tho everything was replace around 27k and everything is good so far but now i think i have a bad bearing too
good luck
Old Sep 9, 2011 | 11:43 AM
1cleanG's Avatar
1cleanG
NextLevel Performance
chips in the steering wheel? got a whole new wheel and top dash pad from warping(same as you)
ryang37x
Aug 21, 2015 03:27 PM
drewfinity
Aug 20, 2015 08:17 PM
drkashifa
Aug 18, 2015 04:38 PM
Digilog
Aug 17, 2015 03:54 PM
350zrunnin12s
Aug 9, 2015 09:55 PM
