TSB - Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Itb09-009 FRONT BRAKE SQUEAL / SQUEAK NOISE
Old Jul 15, 2011 | 01:36 PM
  #76
Xenolith666's Avatar
Xenolith666
Have the same issue.. been going on for awhile now on an '08 G37S.. squeaks like crazy in reverse. When I brought it into the dealer they cleaned out the pads for brake dust; that cured it for a few days, but the squeak remains.
So is it the pad, or the rotor? Maybe getting some slotted, or drilled, rotors will solve the problem?
Old Jul 17, 2011 | 06:47 PM
  #77
BooSa37's Avatar
BooSa37
Dealers will do any of the following:
1.Resurfaced your rotors or replaced.
2.Replace brake pads depends on how much left.
3. Clean out the brake dust from pads and you're done
4. Denied work, saying is normal
all i mentioned above varies depending on dealer.
Old Jul 18, 2011 | 10:13 PM
  #78
mw09g37's Avatar
mw09g37
it's not your shoe pads
it's the e-brake... they have to remove the entire assembly and inspect the e-brake. infiniti had the same problem with the FX. I figured this out after ripping the damn thing apart after being told the same thing. essentially the pad wears funny, and brake dust accumulates. they'll have to replace and clean.
Old Jul 23, 2011 | 04:02 PM
  #79
mjunod's Avatar
mjunod
I had my front brakes services twice by the dealer. Initially they said squeak when reversing was normal. But when in for maintenance at 12K miles, Tech said noise was very loud in service bay so they cut rotors and replaced pads. Squeak return shortly thereafter. At 27K complained but serviced noted it was normal and no TSB. Another time in for service at 44K miles tech noted front rotors causing brake pulsation and heat spots on rotors. Repair stated "replaced pads, back plates and cut rotors per TSB." Noise never returned and now at 57K miles. (2008 G37S)
Old Jul 23, 2011 | 04:47 PM
  #80
A_Palaroan's Avatar
A_Palaroan
hey guys i just got this tsb done to my car. i took it into tustin infiniti and they took great care of me. they resurfaced my front rotors and replaced my front pads. no more squeak.
Old Jul 23, 2011 | 07:11 PM
  #81
ShyAznB8oi's Avatar
ShyAznB8oi
how much did you pay? my front brakes are squeaking already and im at 17,8xx miles already.
Old Jul 23, 2011 | 07:28 PM
  #82
mw09g37's Avatar
mw09g37
there is no ITB for the reverse break squeak. To be honest, your service technician/engineer needs to be good at his job to get it fixed.
the front rotors, limited to the journey non-sport, has an ITB for prematurely warped rotors. BUT that only applies for the vehicles within 12months /12k
Old Jul 24, 2011 | 01:22 AM
  #83
A_Palaroan's Avatar
A_Palaroan
i didnt pay a dime! they even replaced the foam on both driver side and passenger side where the window goes up in and gave me new wiper blades. Tustin infiniti rocks
Old Jul 24, 2011 | 05:36 PM
  #84
mw09g37's Avatar
mw09g37
lol you got lucky, the 08 SPORT doesn't qualify for this ITB, unless the technician sites the same symptoms.
Old Jul 24, 2011 | 05:53 PM
  #85
BooSa37's Avatar
BooSa37
Originally Posted by mw09g37
lol you got lucky, the 08 SPORT doesn't quality for this ITB, unless the technician sites the same symptoms.
Correction, I got that done on my 08 Sport no questions ask. I did took a copy of the TSB with me though.
Old Aug 17, 2011 | 05:37 PM
  #86
bat6wc's Avatar
bat6wc
thank you for this information. just dropped my car off at the dealer and they are ordering new pads and the hardware kit for this fix, all under warranty. hopefully this fixes the squealing!!
Old Oct 12, 2011 | 03:22 PM
  #87
eVitO's Avatar
eVitO
I have a little squeak coming from what sounds like my right front rotor when I just start off, obviously w/o the brakes applied. At first I thought it was only on cold starts and the pad just get stuck to the rotor, but I've noticed it after driving it for a bit too.
I have an '11 sport though, so I'm not sure where or how I fit into this...
I'm not too worried about it and I usually don't even remember it until I randomly here it when I'm taking off from a quiet neighborhood, but just wanted to get an opinion on it.
Old Oct 17, 2011 | 11:09 PM
  #88
KellySA's Avatar
KellySA
Thank you for all of the info that I can take to the dealership. I have 30k miles on my '09 and took it to the dealership for horribly squealing breaks at my last oil change and they told me that the noise in normal and my breaks are fine. I am a realtor and my clients look at me out of the corner of the eyes when the breaks go to town. It is so embarrassing. My husband tells me that it is the sound of Infiniti! HAA I have a couple of other noises going on in the car now and with the breaks, I am about to drive it off a cliff.
Old Oct 17, 2011 | 11:12 PM
  #89
P Casey's Avatar
P Casey
just a fyi its brakes
Old Oct 17, 2011 | 11:26 PM
  #90
bat6wc's Avatar
bat6wc
ive tried numerous TSB and i still have constant squealing under medium braking. happens every day every time. Dealer also says this is normal. "all brakes squeal" my brakes did not qualify for this particular TSB because apparently my pistons on the calipers are different. Im due for new pads soon and im hoping by going aftermarket, ill get rid of the squeal.
