The M - Spot General discussion for the M35/M45
Horn keeps blowing
Old Jul 9, 2009 | 09:14 PM
iLlmAtIc21390's Avatar
iLlmAtIc21390
Horn keeps blowing
On my dad's M the fuse for the horn keeps blowing. Not often but like 3 times in the past month. The horn sounds weird too. It doesn't sound like it use to. If you hold the horn long enough for about 10 seconds straight the fuse blows. I checked the wiring with a multimeter and it's getting voltage so it's obviously not a wiring problem. Could it be the relay going bad? Or the horn itself? May I remind you the horn doesn't sound like it usually sounds like. Help would be appreciated
No warranty guys
Old Jul 9, 2009 | 09:26 PM
ucla bruin's Avatar
ucla bruin
Can you take a video of how it sounds? Does it sound more high pitch than normal?
What was the voltage? Since you have a multimeter, can you get the current running through it too? Might be something wrong with the resistance, too much current will blow the fuse.
__________________
Amaadkhan2k
Oct 4, 2024 01:20 PM
Victory
17
Oct 27, 2022 03:45 PM
cshawsg37
Sep 25, 2015 05:33 PM
lobuzz311
Sep 15, 2015 10:09 AM
