The FX-Spot General discussion for the FX35/FX45
ATESSA Noise????
Old Jan 19, 2007 | 03:06 PM
carrera mike's Avatar
carrera mike
Question ATESSA Noise????
Hello to all. You guys have some sweet FXs here. I just got mine 1.5 weeks ago and here's a pix.
I also have a question pls...
Is it normal to hear the ATESSA dissengage??? I keep hearing this "clunk" at around 19~20 mph after the intial launch(carefull to moderate acceleration). I'm still in the brake in period with an '07FX35.
Thanks in advance!!
~Mike
07 FX35 AWD
911 Carrera Albums>>>Carreras
Attached Thumbnails ATESSA Noise????-img_0036_sml_121.jpg   ATESSA Noise????-img_0034_sml_165.jpg
Old Jan 19, 2007 | 05:38 PM
R2 V35's Avatar
R2 V35
A.K.A. fXg35rIdA
Never heard that cluncking noise on my FX. Go to infinitifx.org and do some research or better yet, take it to the dealer! Goodluck!
Old Jan 19, 2007 | 07:02 PM
da mayor's Avatar
da mayor
only clunk i hear is if i floor the FX from second gear to third gear and it's 100% rwd
Old Jan 19, 2007 | 09:38 PM
GJBenn85's Avatar
GJBenn85
Is it possible that you're hearing the VSC/traction control self-check system? It makes a clunking noise at about the speed you mention during the first acceleration of each start-up. Should be mentioned in the owner's manual.
Old Jan 20, 2007 | 07:20 AM
carrera mike
Thanks Gents!!
GJBenn, you;re the secone one who mentioned that. That could be it then! 'cause when the first guy told me that, I thought he meant that the self check happens while still stopped... good thing you mentioned that it happens at the speed I mentioned.
Mike
Carrera Albums>>> Carreras
Old Jan 20, 2007 | 09:07 AM
carrera mike
Thumbs up
Thanks GJBenn! Found it in the manual, pg 5-54, under ABS, Self-test feature!
NO MORE WORRIES!
Mike
fuzzed
Aug 21, 2020 09:35 AM
Rybitron
Nov 18, 2015 03:11 PM
si_driver
Oct 1, 2015 09:53 AM
MrRiv
Sep 29, 2015 04:59 PM
Slapshot1
Sep 27, 2015 08:40 AM
