Plasti-Dip works wonders!
Old Nov 12, 2010 | 07:00 PM
  #61
Gee37S's Avatar
Gee37S
Originally Posted by GofPHX
I live in Arizona where the temps can go up to 110 degrees!!! Would it be safe to plastidip my wheels???
Try it and find out. WORSE case scenario is that you'll peel it off. Worth the try.
Old Nov 12, 2010 | 08:05 PM
  #62
soundmike's Avatar
soundmike
It really depends what the wheel design is and ultimately how fast it can dissipate heat coming from the brakes and tires. PD is rated to 200°F. If you really push the car, the brakes and the tires, those wheels can get pretty hot.
If you really want to know how PD will hold up at those temperatures, just get a piece of metal (empty soup can works), spray with PD and put it in the oven using incremental heat settings, starting at 110 degrees.
Old Nov 13, 2010 | 12:55 AM
  #63
anacondatp's Avatar
anacondatp
did you paint the back or the inside of the wheel too? or just spray on the outside?
Old Nov 13, 2010 | 05:49 PM
  #64
anacondatp's Avatar
anacondatp
guys, do i paint the back of the wheel and the inside too or do i tape it up?
Old Jan 26, 2011 | 09:49 PM
  #65
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
bump for this thread.
has anyone changed to new tires with a plasti diped stock rim? ie. dismounting at a tireshop and remounting? I'm guessing this won't hold up and will need a redo?
Old Jan 27, 2011 | 02:12 AM
  #66
Andyrox's Avatar
Andyrox
wow, very nice! im really digging all the mods on your car, it looks very clean.
Old Feb 1, 2011 | 08:12 PM
  #67
simpson_G37X's Avatar
simpson_G37X
Originally Posted by cereal2k
They actually have plasti dip in clear.
Does anyone know if the clear plasti dip is gloss? or matt same as the black? i have a feeling it would be matt.
im definately considering doing this to my G37x wheels but not too sure how the flat black would look on an AG coupe (or black in general for that matter)
Old Feb 1, 2011 | 11:06 PM
  #68
cereal2k's Avatar
cereal2k
I could never find it at my local home depot/lowes. Not sure.
Old Feb 1, 2011 | 11:23 PM
  #69
simpson_G37X
might have to do some experimenting then if i can find it haha
Old Feb 2, 2011 | 01:11 AM
  #70
TheIvoryG's Avatar
TheIvoryG
I finally tried this stuff today, but on a bicycle part. I sprayed some aero bars on my commuter bike instead of using tape like I normally would. I have to say that this stuff sprays on like it is going to have all kinds of orange peel, but actually cleans up pretty well when it dries. Did a few coats today so really didn't handle it much, but when I did feels pretty good. I think I'm going to like it a lot for this particular application. Problem is going to be trying to not pull it off, just to see how easy it is to remove!
Old Feb 2, 2011 | 07:45 AM
  #71
soundmike's Avatar
soundmike
^ Peeling it is quite easy and leaves no residue whatsoever. Take a look at this thread
Peeling back plasti dip - G35Driver
Old Feb 2, 2011 | 11:22 AM
  #72
simpson_G37X
aaahhhh finally an answer to the "can you paint over plasti dip" question that's everywhere. any suggestions on colour for an AG x coupe?
Stock wheels painted using Plasti-Dip - G35Driver
Old Feb 2, 2011 | 01:05 PM
  #73
dwildemn's Avatar
dwildemn
Black PD with Blue Slate and stock (non-sport) wheels? Bad combo or worth a try?
Old Feb 2, 2011 | 02:22 PM
  #74
tomro99's Avatar
tomro99
i say go for it. you'll never know how good it looks until you try it. the only loss is a couple hours of your time.
Old Feb 2, 2011 | 02:32 PM
  #75
cereal2k's Avatar
cereal2k
This is awesome. Thanks for linking this!
