dash lights out. Speedo and odometer
Old Aug 26, 2023 | 12:31 PM
  #31
ILM-NC G37S's Avatar
ILM-NC G37S
I am assuming the light was not a issue before this fiasco ensued? Because you likely did not disconnect the battery when you removed the preset switch panel (the clock one) to replace the amp, this is why the SRS light is blinking/ on.
Here are the SRS Light Reset instructions. This works 99.9% of the time.
If the issue persists, and there is a known pre-existing event, you might need to have the issue looked at by a reputable mechanic.
Old Aug 26, 2023 | 04:11 PM
  #32
mstocker1's Avatar
mstocker1
It work, no more airbag :-) now I just filled up the gas tank and I just need to run a little bit to make sure the needle goes down.
Hopefully now everything is good. If the needle doesn’t go down, I don’t know if it’s possible that I purchased a bad used parts for that a/c part
we shall see!!
thank you again, everybody..
Old Aug 26, 2023 | 04:37 PM
  #33
ILM-NC G37S
Originally Posted by mstocker1
...I just need to run a little bit to make sure the needle goes down.
mmm hmmm... You just want a excuse to zip around town all good.
Hitters
Sep 15, 2022 09:12 AM
2KD11.G37X
Apr 12, 2022 09:20 PM
sLADe781
Feb 16, 2020 08:27 AM
Curtis Roberts
Aug 4, 2018 02:53 AM
Dannyplox
Apr 9, 2017 06:56 PM
