HELLO G37ers
HELLO G37ers
HELLO,I Just Purchased An '10 G37xs woman got crazy man try bypass wire harness so her husband took it too nissan and now the car won't come back on I've read lots these threads like I do see dampness on passenger side,the start of her problems was no dash lights no heated seat and I think radio was working.now the car key won't recognize locks or the manual slot she brought a new key guy couldn't get it programed? Am I making any sense sorry any suggestions would help thanks everyone
Well, that's not a 2010 front end.
I bet you it has a 2009 rear end, too.
Put your VIN into the decoder: https://www.myg37.com/forums/vindecoder.php
You know, the driver's side fender paint doesn't match the driver's door at all, so maybe there was a repair job at some point, and they went all frankencar on replacement parts?
I bet you it has a 2009 rear end, too.Put your VIN into the decoder: https://www.myg37.com/forums/vindecoder.php
thanks boss I may have someone with the programing im just trying to re avoid dealer I don't have the 1400 they think it a programing is g9ing to take,Also if my stupid brother let the windows down how could I hot wire a wire from battery to window motors to roll up ? Pretty sure I messed more up im just inpatient and no hometown help thank u guys !
At least that is how I did it in the old days. Of course that was before all this safety-based electronics took over. Should still work either way.
What door?
In theory, you would have to take the door panel off and "hot wire" the motor directly. I would ONLY do this as a last resort and with the car battery COMPLETELY DISCONNECTED from the car.
What door?
What door?
Sorry, but that is not how this window system works. There is a small "network" between the BCM and the Driver door switch module (herein "master") and the other three (3) door switches (herein "slaves"). Everything goes through the driver side "Master" switch. One has to request permission from the other before the window, or locks, can move. If any link in that chain, like the BCM issues you are having now, goes down, nothing moves.
In your case, you would have to take each door panel off, using the factory wiring diagram determine what two pins at the motor you would need to "jump" to close the window. Doable, but very time consuming.
I hope you are not going to be going down the proverbial rabbit hole of problems with this car? Seems like the previous owners really screwed it up...
Good luck.
Good luck.
@ILM-NC G37S Do the windows go through CANBUS? or are they just all wired through the driver's door switch?
If the latter, he should be able to pull the drivers' door switch out of the door panel (carefully) and provide power to 12V and ground wires into the switch. I would DEFINITELY do this with the battery disconnected. Then use the driver's switch to put all the windows up.
If it's CANBUS and your BCM is borked, well, good luck - better buy a tarp.
