2013 g37x transmission issue ofc
Old Feb 27, 2021 | 06:14 PM
cumron's Avatar
cumron
Angry 2013 g37x transmission issue ofc
Hi guys! I just bought a G 2 months ago, and the transmission is really pissing me off. So lets say youre turning a corner in a high gear, then you go between 1/4 throttle and 2/3 to re accelerate. The car refuses downshift, bogs, then downshifts like 4 seconds later. Never does it in manual mode. Also, when the car is started first thing in the morning, it drives well for 4-8 minutes. then when the trans gets up to temp, it hunts for 7th, bogs constantly, and has rough upshifts almost like TC shudder. Any help would be just amazing. Flushed ATF last month, has all the updates according to Infinity of Dayton. I hope this car lasts and is okay, ive had too many problems in the past. made me have vehicular ptsd haha
Old Feb 27, 2021 | 06:25 PM
Tatus's Avatar
Tatus
Do the ecu relearn
Old Feb 27, 2021 | 06:29 PM
cumron's Avatar
cumron
Ive done this as well.
Total things done
1. Update re applied January
2.ECU reset January
3. Idle relearn January
4. ATF flushed January
5. Throttle bodies and Mafs cleaned by dealer, only took 40 minutes for some reason
6. Injector cleaner febuary
Old Feb 27, 2021 | 06:36 PM
Tatus's Avatar
Tatus
Did you do the relearn after the trans fluid change?
I just did my throttle body cleaning this afternoon since its 50 degrees in chicago today. Took me almost 2 hours cause I did it right not just sprayed some cleaner while the throttle body connected to the intake which Im sure is the way dealers do it.
Old Feb 27, 2021 | 07:20 PM
cumron's Avatar
cumron
Hmm no I didn't know that was a thing that needed to be done, ill add that to my list. Is ir just the pedal dance or an actual relearn?
Alex Sinitsky
May 28, 2019 12:30 PM
Descendent
Jun 7, 2017 03:57 AM
lfeder
Jun 6, 2014 06:47 PM
