I Have $_____ , what can I do? (Performance)
Old Oct 26, 2015 | 10:36 PM
  #46
RxRyanM's Avatar
RxRyanM
Originally Posted by harryg37
Hey guys, I'm new here. I'm 18 years old and I just bought my first car, I went with a 2013 g37 sedan. Its got about 30k miles and I want to do some stuff to it, but I am a car newbie and need some guidance. Anyone out there want to help your boy?
No one can tell you what to do with your car (with the exception of Rochester, who will tell you to get sways - do that). It's up to you. What do you want to do with the car? What's the end game?
And this isn't the thread to discuss it in. Make a new thread in the newbie corner or whichever sub-forum you want that's pertinent to the topic.
Old Jan 2, 2016 | 10:03 PM
  #47
Wasekcj's Avatar
Wasekcj
Muffler delete too makes the car sound very nice
Old Jan 28, 2017 | 11:36 AM
  #48
Inali's Avatar
Inali
How did you afford such an expensive first car...
My first car at age 18 was a $500 rusty purple Honda Civic sedan.
Old Jan 29, 2017 | 03:40 PM
  #49
harryg37's Avatar
harryg37
Started my first business at 14 years old, started two more junior year of high school. Been working hard for awhile
Old May 25, 2017 | 09:31 AM
  #50
pan0phobik's Avatar
pan0phobik
New G37x owner here. Thanks for this thread!
Old Sep 5, 2017 | 05:14 PM
  #51
Eric Balmilero's Avatar
Eric Balmilero
Great
Hello friends,
I was reading some threads and realized that a lot of people come here with limited budgets, but still want to maximize their enjoyment of the car. For some, enjoyment is derived from horsepower (me), for others, it's from a beautiful car.
Disclaimer
I'm going to break this down in increasing budget, so skip to the appropriate section. I'll go from $150, $300, $600, $1000, $3000, $5000, and $10,000. As a disclaimer, this is my opinion, I already told you that I'm biased towards power mods. I will revisit this and generate another thread (if you want) with aesthetic mods. I'm going to assume you already have the necessary tools and equipment for this, even though I know much of the stuff I mention might be specialty. There will also be a lot of DIY assumed here, shop time eats up a lot of cash.
$150
So you've got a fresh new G37 and want the most bang for buck. Congratulations on your acquisition. I understand, you won't be buying a turbocharger for a single C-note, but you can definitely increase the performance of your car.
MyG37.com Sticker ($6.50)
Obviously the best return on investment. Put one of those bad boys on your car and you'll FEEL the difference. Click on the link in my signature if you want one.
Oil Change ($53.50)
Change your regular oil out for some full synthetic. It's a vast improvement over the regular stuff, and will help protect your investment.
Brake Fluid ($30)
Ditto for brake fluid. The OEM stuff is good, but if you bought your car used, you have no idea the last time the previous owner flushed the brake fluid. I like Motul 5.1, or RBF600. There are plenty of other threads detailing peoples' favorite fluid.
Car Wash ($10)
Clean your car, I mean REALLY clean it. Every bug or ding in your radiator, every scratch on your headlight lens will decrease the performance of your car. Get in there and clean out the bug guts, detail your headlights, and make sure there isn't brake dust built up in your wheels.
K&N Replacement Filters ($50)
K&N makes great filters. They come with a lifetime warranty, are reusable, and will net you a small (very small) amount of horsepower over the stock filters.
$300
Okay, you've had a birthday, maybe christmas, and you've got a little bit of pocket money to spend on your car. Doing the stuff above is still a good idea, but $300 will go a lot farther towards felt performance increases.
$300 is still too low to get a proper long tube intake, but you might be able to pick up a filter replacement/tube replacement for your intake.
HPS Silicone tube intake + filters ($130)
This will replace your OEM airboxes with an unshielded pod filter. The increased air will let your motor breathe a little better and give you just a tad bit of engine bling. The silicone hoses will keep your air charge cool.
Grounding Kit ($40)
A grounding kit will help automatic transmission guys more than it will the manual guys. On the 7AT, it will clean up your shift times, it DRASTICALLY reduces the delay when shifting with the paddles, and increases your audio performance to boot. On the 6mt, you're the one in control of your shifting, but you still get the benefit of peace of mind and a better stereo experience.
Stainless brake lines + Brake Flush ($130)
Technafit brake lines and brake fluid will go a long way towards firming up your pedal feel. The car is plenty fast to begin with, and before long, you'll probably want to stop. Brake job is going to be a recurring theme in the rest of this thread.
$600
$600 is just enough to be dangerous. You can either accentuate your OEM equipment by augmenting what's there, or you can replace some of the big bottlenecks in your airflow system. I'm not going to detail anything here, pick and choose from the $300 and $1000 recommendations and select what's important to you.
$1000
Though this isn't quite enough for a proper full exhaust and intake replacement, it IS enough money to let you modify your exhaust to coax a few more horses out.
Long Tube Intakes ($400)
Long tube intakes will pull cold air from near the bottom of your engine bay, or even outside your engine bay. Cold Air = Dense Air, meaning you can increase your proportional amount of fuel.
Test Pipes ($200)
It's no secret that the OEM catalytic converters, though eco-friendly, are the biggest bottleneck in the system. They represent a significant restriction in your exhaust and can be replaced by simple pipes. Note: I am not advocating this highly illegal car modification. Even if it DOES present you with more horsepower than high flow cats.
Muffler Delete ($100)
Beyond the catalytic converters (cats), the muffler is the next biggest bottleneck. I hate this mod, but it DOES eliminate the bends and backpressure associated with a muffler. You can get a muffler shop to unbolt your canister muffler (coupe), or dual mufflers (sedan), and weld straight pipes instead. Be prepared to deal with the noise, rasp, and smell associated with a straight pipe setup.
Previously Mentioned Fluid Flush and Brake Job ($250)
Told you this would become a regular thing.
$3000
This kind of money will let you do your intake AND your exhaust. It's not quite enough for the best of everything. This is where you start deciding what's important to you. You can cut corners with your exhaust by purchasing test pipes, or you can opt to stick with a short ram style intake.
Long Tube Intake ($500)
Discussed Previously
Test Pipes ($200)
Previously Discussed
Axleback Exhaust ($400)
Aftermarket muffler
Upper Intake Manifold ($500)
The upper intake manifold, manufactured by either Z1 or Motordyne, will allow clean air to flow from your intake as smoothly and evenly into each cylinder as possible.
Professional Tune (Uprev) ($500)
A tune is honestly something you should be doing in addition to the $1000 dollar mods above. A tune will add maps to your factory ECU and allow a tuner to rewrite the way the car behaves under load. It teaches your car what to do with those nice mods you're installing, and prevents you from potentially leaning out and detonating in your cylinder.
Lightweight Pulleys ($200)
Lightweight pulleys shave weight off the rotating parts of your car. They allow you to accelerate noticeably faster, and have proven gains on the dyno.
Track Day ($450)
The most important thing you can improve in your car is the person sitting in the drivers seat. Go to an educational track day, learn how the car behaves under load, and learn how YOU behave under load.
$5000
This is probably the most money you'll want to spend on pure performance before going forced induction. With this, you're going to want all the bolt ons and a tune. Attend.
Long Tube Intakes ($500)
Discussed previously
Long Tube Headers ($1200)
Long tube headers scavenge exhaust from your cylinders and conduct it into your catback. The only manufacturer of long tube headers (LTH's) that I know of is Fast Intentions. Their design lets you pick up maybe 10 horsepower above test pipes + stock headers .
Free Flowing Exhaust ($1400)
You can afford a proper aftermarket exhaust. As far as power gains, one exhaust is much like any other. You're looking to reduce/eliminate things that cause backpressure. Look for an exhaust made from Stainless steel (good insulation), mandrel bends (smooth), and as few turns as possible.
Uprev Tune ($500)
Installation for headers + exhaust ($600)
Headers isn't something you want to do yourself. It's a pain in the butt, and it easier to do on a lift.
Oil/Transmission/Differential/Coolant/Brake Flush and refill ($200)
Stainless Brake Lines ($100)
$10,000
Woooooo! Look at you, high roller. You've got dough to throw around and you're not afraid to let everyone know. Obviously, the answer here for max horsepower is forced induction. Screw cold air intakes, screw pocket tunes, and fuel efficiency. You want to fly.
Stillen Supercharger Kit ($6800)
Well, that went quickly. $6800 is approximately how much a supercharger kit will cost to be shipped to you. Superchargers provide a more linear power band than a turbocharger does, and are lower maintenance. This is my damn thread and I'm doing a supercharger, got it?
I like the Stillen kit in particular because they address the problem of fuel management. They include bigger injectors AND a tune in the kit.
Exhaust ($1200)
You need to open up your stock exhaust for the same reasons you put an aftermarket exhaust on your car even when it was naturally aspirated. This will allow your supercharger to do its work more efficiently, and will sound awesome, to boot.
Install ($1500)
Buying the kit isn't the only expense, unfortunately. Forced induction is the kind of thing you want a mechanic to install. Improper installation can lead to some very serious consequences (read: Kaboom), and you'll rest better knowing it's someone else's fault if your motor blows up.
Professional Tune ($500)
You get a tuner cable with the package, but nothing beats a proper, professional dyno tune. Your tuner will put your newly supercharged car through its paces on a dyno, and use the feedback from the machine as a diagnostic tool to determine exactly what your car wants.
job on this write up. I love it. Helps put budget into perspective for me.
Old Mar 14, 2018 | 03:58 PM
  #52
Sharp2415's Avatar
Sharp2415
Where can I get a tune from
i just bought a stillen Gen 3 long tunes intake and deciding between stillen cat back wxhaust or HKS really do t which way to lean on it. But I would like to get a tune also just don’t know where to get one at.
Old Mar 14, 2018 | 04:00 PM
  #53
slartibartfast's Avatar
slartibartfast
Welcome to the site.
Just google ecutek or uprev near you.
Old Mar 14, 2018 | 05:29 PM
  #54
Sharp2415's Avatar
Sharp2415
Okay coo. Thanks for the info.
Old Mar 14, 2018 | 06:46 PM
  #55
slartibartfast
You could also post your question in the SoCal forum.
https://www.myg37.com/forums/southern-california-321/
Old Jul 22, 2018 | 07:24 AM
  #56
Comicguybri80's Avatar
Comicguybri80
Thanks
This is a fantastic thread especially for a noob like me I appreciate that you put all the ballpark numbers in there and also it's a bit of a guide to a guy who's not to sure where to start tha bbn is so much!!!!!!
Old Aug 16, 2021 | 03:58 PM
  #57
RYNO 76's Avatar
RYNO 76
Great Read
This is a great post. I just bought a G37x and I am trying to decide what type of performance I want out of it. I am not an import guy, my modification and drag racing background is limited to everything LS and LT. This a good guide to see what I can do with 5,000 to 7,500 dollars. I don't need anything crazy, just some extra horses would be nice.
Old Aug 16, 2021 | 04:37 PM
  #58
BULL's Avatar
BULL
Moderador
Hello there, don't know if you read the whole thing but it's a good way to start since most of these mods have now accrued time and mileage.
The VHR responds well to exhaust and intakes but most significantly a tune.
Intakes can be had for under $400
Exhaust I suggest to go with whatever you muffler shop can handle $400
Tune $900
So for +/- $1700 you'll gain an average of 30+/- whp difference. Anything more than this will require more money for the difference it will make. Used parts can offer significant costs savings, same with the tuning. Some folks can offer cheaper prices if you're local to them.
Old Feb 27, 2022 | 08:00 AM
  #59
EJM's Avatar
EJM
Prices have increased dramtically
Great Thread, but the prices need to be updated. Lol. I’m new to the game. I have 2k, I’ll be lucky to get an exhaust and throttle body installed.
Old Feb 27, 2022 | 02:45 PM
  #60
You know, I've never read this thread before. That original post was a really good read.
8 years later... LOL
Seems very focused on performance as it pertains to power, which is fine, it is what it is. Someone should do a similar thread focused on handling... suspension, tires, various LW parts, etc.
infinitidummy
Nov 21, 2021 06:22 PM
aravin
May 12, 2020 10:13 AM
Jedz123
Apr 20, 2016 12:27 AM
syrusdavirus
Apr 8, 2016 03:18 PM
xjcx
Oct 26, 2013 05:33 AM
