Road Noise
Old Mar 15, 2014 | 11:04 AM
mikej3's Avatar
mikej3
Road Noise
Just purchased 2010 G37X Sedan. 30,000 miles. Has original Goodyears tires. Last night driving over 70mph on smooth asphalt I heard loud growl (road noise). Dropped off under 60. Is this the tires? I plan to replace in next 5,000 miles. Any recommendations?
Old Mar 15, 2014 | 01:05 PM
Welcome to the site Mike, congrats on your new X
More than likely it would be the tires, 30k is getting close to the end and those Goodyear RS-As are a truly horrible tire. I replaced my RS-As before my first oil change on my 09 they were that bad
Whatever you do get a different tire
Also check for proper tread wear, your alignment may be off and that could be a factor in the road noise you're hearing.
Good Luck,
Brad
Old Mar 27, 2014 | 11:23 AM
mikej3's Avatar
mikej3
Thanks. Plan to put on either Hankook Ventus S1 or Bridgestone Turenza Serenty Plus. Had Hankook Ventus V4 on 2008 G35 I used to have. They were pretty good. These are supposed to be better. Ranked at the top for Ultra High Perf on TireRack. Any other suggestions or feedback
Mike
Old Mar 27, 2014 | 10:40 PM
itzricky's Avatar
itzricky
Continental extreme contact dws
Old Apr 15, 2014 | 01:07 PM
TommyBluez's Avatar
TommyBluez
Mike
What did you go with? I was thinking about the Ventus S1's myself.
Rybitron
Nov 18, 2015 03:11 PM
rk325
Oct 13, 2015 01:51 PM
si_driver
Oct 1, 2015 09:53 AM
Awgd8
Sep 30, 2015 06:22 PM
Slapshot1
Sep 27, 2015 08:40 AM
