Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Which is more important for dissipating heat on the track?
Old Jan 27, 2020 | 05:52 PM
  #46
TheDevilsG's Avatar
TheDevilsG
Maybe you guys could try greasing the edges. I've heard people complain stock S pads were a tad squeeky before and i was a bit surprised by those complaints since mine never make a sound. I know we are all on different pads but cant hurt right?
Also cleaning up those sliding pins may help too. Mine were a tad rusty so i used a wire brush to clean them up and grease them just a tad.
Old Jan 27, 2020 | 05:54 PM
  #47
TheDevilsG's Avatar
TheDevilsG
And about the SPs stopping 1/2 the distance and feeling like you are going through the windshield, Now you have me wanting to buy them before mine are even worn out
Old Jan 28, 2020 | 12:44 PM
  #48
4DRZ's Avatar
4DRZ
Yeah, the Carbotech XP12/10 pads are awesome, but a bit much for the street. After a track day when I drive home I always have to remind myself to take it easy on the brakes so no one rear ends me because I stop so much quicker. Then I switch back to my street pads and it feels like it takes forever to stop.
Old May 1, 2020 | 07:50 AM
  #49
Big Jaw's Avatar
Big Jaw
Originally Posted by Rooster Tail
That's all. Imo, and I can be opinionated 😉, the 6 piston calipers bring nothing demonstrable for 99.999% of drivers. Assuming a little more caliper piston area, slightly longer pedal travel, and therefore a slightly longer modulation range. Something no one will notice.
hi, new here.
increased pad area/volume normally means increased heat capacity (pads won’t have same temperature as rotors), decreased specific pressure on the pads (to have same clamping force), reduced risk of heat spot on the rotors, decrease energy per area for the pad (each material has its limits related to energy/area)
i am considering a 6 pot properly adjusted, obviously. As pad pressure distribution, pad slots and so on will have significant effects.
if this will make enough difference for you setup? I have no idea, would need to setup a proper temperature measurement through the sections and verify. Maybe your issue is more related to brake balance (are the rears temp way colder than fronts? Or vice-versa)
Old May 1, 2020 | 05:56 PM
  #50
4DRZ's Avatar
4DRZ
The brake balance is good in my car with my pad compounds. Ultimately, it comes down to asking a lot of the brakes on track due to the fact that they were originally engineered for the lighter 370Z. The original question was if it makes a bigger difference to have bigger rotors or bigger calipers.
Old May 1, 2020 | 06:16 PM
  #51
Big Jaw's Avatar
Big Jaw
I would say, it depend on the situation. Probably, bigger rotor, improved fin design and material that can handle better the temperature changes.
brembo has some new fancy designs that dissipates more than the curved fins.
but if the problem is more related to thermal cracking due to hot spots, simply going to bigger rotor may not solve the issue.
Old May 3, 2020 | 10:11 AM
  #52
4DRZ's Avatar
4DRZ
That seems to be the consensus that larger rotors are more beneficial. Probably a lot cheaper too in most cases. Or we could just get cars that weigh a lot less. I don't know why car companies won't spend more time trying to make their sports cars lighter. That would solve so many issues. Instead the trend seems to be to just throw more power at everything.
Old May 3, 2020 | 12:04 PM
  #53
Big Jaw's Avatar
Big Jaw
Have you ever seem someone throwing a brake bar on that? Or else a brake proportional valve (more likely to fit)? To brake on the most efficient way.
i would like to run some test on your car, if I had a VBox and some thermocouples.
new vehicles are heavy or BRZ/Miata. I didn’t like those, and I don’t know why. That’s why I am looking for a G37 myself
Old May 6, 2020 | 10:24 PM
  #54
4DRZ's Avatar
4DRZ
No need, the balance is actually pretty good. I take brake temps on the car when I track it.
Old May 7, 2020 | 10:47 AM
  #55
Big Jaw's Avatar
Big Jaw
Saw in other post that you run already different friction materials on front and rear. Must be sufficiently balanced.
Sometimes on formula cars they setup a specific balance for each deceleration level, which for sure it’s a overkill for track days.
Old May 7, 2020 | 10:58 PM
  #56
4DRZ's Avatar
4DRZ
I've experimented with a lot of compounds over the years, but I can't take credit for this one. Spencer at Z1 recommended the last Carbotech set up and it works great.
Phantom_G37S
Nov 12, 2018 02:40 PM
amdiboy
Nov 6, 2018 10:19 AM
sicko
Jul 25, 2014 01:11 AM
DPE G
Apr 26, 2012 10:06 PM
2GoRNot2G
Sep 21, 2009 08:06 PM
