Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Realistic 1/4 time in PHX, AZ?
Old Mar 10, 2014 | 08:37 PM
MP87's Avatar
MP87
Does anyone know, more or less, what 1/4 times and trap speeds I can expect to achieve in a bone stock G37S 7AT in Phoenix, Arizona? If you have summer times and winter times that would be great too. Thanks!
Old Mar 10, 2014 | 09:15 PM
Vizard_87's Avatar
Vizard_87
Here are some threads to give you an idea
https://www.myg37.com/forums/motorsp...times-g37.html
https://www.myg37.com/forums/g37-sed...1-4-times.html
https://www.myg37.com/forums/g37-sed...ast-night.html
I ran 13.7 stock
Old Mar 11, 2014 | 07:30 PM
MP87's Avatar
MP87
Thanks Vizard. I was hoping to find AZ specific times due to the higher elevation. I think Firebird International (PHX, AZ) is around 2000 feet elevation, so I expect the Gs to run a bit slower than people who are at, or close to, sea level.
Old Mar 11, 2014 | 11:08 PM
MrJCole13's Avatar
MrJCole13
I thought firebird closed last year?!
Old Mar 13, 2014 | 05:25 PM
rmfnla's Avatar
rmfnla
I thought that was only an issue with carburetors...
Old Mar 13, 2014 | 05:33 PM
G37Sam's Avatar
G37Sam
Higher elevations means the air is less dense. Cars, humans and anything relying on Oxygen get affected the higher up you go.
Carburetors just require retuning when ambient conditions change. Fuel injected cars have a ton of sensors to measure and make adjustments to ambient changes. Both setups when tuned will make around the same power when compared to each other regardless of elevation and other ambient conditions.
[EDITED POST TO CLARIFY]
Old Mar 13, 2014 | 05:43 PM
rmfnla's Avatar
rmfnla
Carburetors just require retuning when ambient conditions change. Fuel injected cars have a ton of sensors to measure and make adjustments to ambient changes. Both setups when tuned will make around the same power regardless of elevation and other ambient conditions.
Sounds like you used two paragraphs to agree with me...
Old Mar 13, 2014 | 05:57 PM
G37Sam's Avatar
G37Sam
LOL
I was just trying to explain how elevation would make both cars slower.
Old Mar 14, 2014 | 06:39 PM
geethirtysevenx's Avatar
geethirtysevenx
The second half of your statement is not really correct, as you can not replace the oxygen molecules that are absent from the intake charge by tuning, unless you were to increase the displacement of your engine.
Supercharged or turbocharged engines are less sensitive to elevation changes, but as a loose rule of thumb you will loose appox 10HP for every 1000ft of elevation on a naturally aspirated engine, that is at equal ambient air temperatures and similar humidity levels.
Here is a formula to give you an idea.
HP Loss = (elevation x 0.03 x hp @ sea level)/1000
I would say that if you are running at Phoenix in 95 deg ambient air with a naturally aspirated engine, you are going to be several tenths slower than running at sea level in 75 deg air.
Cheers,
Paul
Old Mar 14, 2014 | 06:50 PM
G37Sam's Avatar
G37Sam
I edited my post to clarify. I never meant to say an injected car will make the same power at sea level and at 5000 ft. I meant Fuel Injected and Carb'd setups will make more or less the same power when fine tuned all else equal.
Old Mar 15, 2014 | 01:04 AM
geethirtysevenx
My bad, I misunderstood what you had written.
Cheers,
Paul
Rick in NC
Intake and Exhaust
27
Jan 6, 2019 09:47 PM
kavcheung
Jan 22, 2016 02:40 PM
OneSickBlackG
Jan 6, 2016 08:49 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
