Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Raced my 08 G37s vs 12 IPL 1/4
Old Mar 25, 2012 | 11:44 PM
  #151
GraphiteG37S's Avatar
GraphiteG37S
I too learned the hard way... This car is nice but bolt ons give it NO power. It's a wate of thousands. I'm sorry I made that mistake.
R2C intakes + Berk HFC + Fast Intention CBE + UpRev Tune = 299whp
Old Mar 26, 2012 | 02:47 AM
  #152
mtrsprt's Avatar
mtrsprt
Originally Posted by ReD2847
Do you think the 7at coupe would of done alot better? It seems alot of people say the 5AT is far from matching the performance of the 7at coupe from off the line...
The 7AT has a super low first gear ratio of 4.92:1, compared to that of the 5AT's 3.84:1
This allows the 7AT to accelerate much quicker out of the gate when traction is not an issue.
Old Mar 26, 2012 | 04:09 PM
  #153
ReD2847's Avatar
ReD2847
I would assume that lower 1st gear will get it off to a better start but the 2nd gear in the 5AT might easily make up for the lost time and keep up with it as its not wasting as much time doing extra shifts.
Wish i can see a video of the 5at vs 7at in a straight line dragging...
Old Mar 26, 2012 | 06:01 PM
  #154
37hevn's Avatar
37hevn
that might be true but when i test drove the 7at i was disappointed when cruising at 60mph in 5-6-7th gear and then flooring it and feeling it slowly in my mind shift through each gear. my 5at goes straight to the gear with little delay and they goes. i went with the 5at for that reason. i also "heard" the 5at is a stronger tranny but to those reading please dont get up and arms about that
Old Mar 26, 2012 | 09:28 PM
  #155
ReD2847's Avatar
ReD2847
That's an interesting comparison. It seems like from a roll the 5at may take the 7at then.
What about any difference from a standstill? Didn't the lower gearing in the 7at feel noticeably quicker or did the extra shifting negate any possible speed gains?
Old Mar 27, 2012 | 01:13 PM
  #156
37hevn's Avatar
37hevn
the 7at's first gear would prolly beat the 5at off the line but i dont think by a noticable amount. also in a race to say 0-130 i would think the advantage would go to te 5at because it wont shift as much but thats my guess
Old Mar 28, 2012 | 10:05 AM
  #157
DashKid's Avatar
DashKid
You are correct in a way. If you are just cruising going about 60 mph and not in sport mode and you floor the pedal the computer has to find out what gear it needs to be in to give it the most power hence why there is a huge throttle lag on the 7at compared to 5at. 7AT has more gear it has to down shift to match the correct gear while 5AT has less gear to match.
Old Apr 8, 2012 | 08:53 AM
  #158
1TUFG37XS's Avatar
1TUFG37XS
Shorter gears like in 7AT should be better than 5AT longer gears thru a quarter mile. The whole concept of more gears (and/or Variable transmissions) is to keep the engine in the max power band as long as possible and improve MPGs while cruising. And since these are autos and shift so quick you are not losing time if they shift one more time vs 5AT thru the quarter.
From a roll it just depends on the speed and where you are in the power band for that gear. If I floor my G37 at say 50mph and it's 3rd gear 4k RPM vs 2nd gear in 5AT at 5k RPM I'd expect the 5AT to get a little jump as its more in the power band. That might reverse at say 60 if 7AT is now in a sweeter spot in 3rd vs 5AT that's now at the low end of 3rd.
Just a lot of factors here to consider.
Old Apr 10, 2012 | 02:16 AM
  #159
ReD2847's Avatar
ReD2847
^^^^ True, but if they did a run on the quarter mile i think the 7AT would need to shift twice more than the 5AT, i dont see how thats not going to make a difference in time.
Although i do wonder if Infiniti updated the 7AT ECU to be faster at shifting than the 5AT. I also wonder if the 5AT in the G37 has been updated from the same 5AT used in the older G35's.
I think all these factors play in when comparing these two trannies with everything else being equal between both cars.
Old May 17, 2012 | 01:05 AM
  #160
mb2zj2's Avatar
mb2zj2
Has anyone driven the 1/4 mile in a 7at? If so, does the trans accually shift 7 times within the 1/4 mile? Remember, these trannys are built for practice "street" performance/ drivability/ fuel mileage, not for drag racing. That being said, I think you will pass the 1/4 mile trap, b4 it shifts into the highest gear. I don't know this, as my car is a 5at, and shifts into high gear right as i pass through the gate. I'm not trying to stir up the pot, just looking for the answer. The only experience with a 7at was at the dealer, test driving a brand new coupe, while being yelled at by the salesman in the back seat to slow down cuz his head was hitting the back window hard over bumps, and while drifting... poor guy, I did apologize!
Old May 17, 2012 | 01:13 AM
  #161
mtrsprt's Avatar
mtrsprt
The 5AT should be going through the traps in 4th, the 7AT in 5th.
Old May 17, 2012 | 01:52 AM
  #162
G37Sam's Avatar
G37Sam
My 5AT trapped in 3rd IIRC
Old May 17, 2012 | 02:33 AM
  #163
mtrsprt's Avatar
mtrsprt
Very possible. I'm sure if it did, it was very close to shifting up again also.
Old May 18, 2012 | 10:07 PM
  #164
37hevn's Avatar
37hevn
mine crossed in 3rd
G37 IPL Bryan
Sep 15, 2015 04:40 PM
Digilog
Aug 17, 2015 03:54 PM
TakmaN
Aug 8, 2015 07:47 PM
