Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Oil Cooler no more limp mode at the track
Old Mar 10, 2010 | 05:29 PM
Mike's Avatar
Mike
Originally Posted by jungwoo0622
on the manual says it will starting to open F160 but
i found that it is open way lower temp like f120
or you can get the sandwitch adapter without termostat so it will open all the time
Originally Posted by w0ady
nice work. any luck finding a low temp thermostat for our cars?
I think he's asking about getting the engine fans to turn on earlier (or stay one permanently....)
Clarification please W0ady!
Old Mar 10, 2010 | 10:43 PM
joo030879's Avatar
joo030879
Unless you live in places like Alaska. Thermostat Sandwich adapter is not needed. I think the thermostat starts at lower temperature, with or without thermostat here in California does not make huge difference.
On other occasion I asked my good friends at Alfa Romeo Club of Southern California. During winter they put a cover over the oil cooler. And remove the cover when they go to Track. Which according to Jim, Thermostat adapter lowers oil pressure, going back into the engine. Jim my good friend is 95 year old, and 45 years of track experience. OLD SCHOOL, with lots of track experience.
Old Mar 10, 2010 | 11:29 PM
joo030879's Avatar
joo030879
W0ady, if it is fan, or water temperature concerns you. On my Water temperature gauge does not go up 1/2 point when I am tracking. Which stays same as my everyday normal use of my G37 Sport. It is the oil temperature that goes up and causes limp mode. I own access port and when oil temperature goes up I get signs of limp mode.
Old Mar 11, 2010 | 04:19 AM
w0ady's Avatar
w0ady
i was asking about the actual thermostat that works your radiator, etc. on the g35 it was 180 F and nismo units opened near 150 but ive really never had any oil issues. i was just looking for an easy way to cool my 7at without going to a trans cooler.
Old Mar 11, 2010 | 07:41 PM
joo030879's Avatar
joo030879
thermostat that works you cooler.....
To be honest I have no Idea. I now know that you have had no issues with Oil Temperature. But this feed is not about radiator. Radiator gauge or coolant temperature gauge can be read from your dash board. Oil temperature tends to go over the limit when you push your car to the limit. Reaching red line on RPM constantly. Causing limp mode to protect your engine.
Oil and water act different under high temperature. Water or coolant inside your radiator will cool much faster than Oil. Coolant or water will not become acidic when heated. However Oil when heated will become acidic and cause damage to your engine.
The very reason we have oil cooler is not to cool the engine temperature. However to avoid Oil from turning acidic. Limp mode is caused by oil temperature, not by engine coolant temperature.
Old Mar 16, 2010 | 09:29 PM
w0ady's Avatar
w0ady
i believe the reason i havent had oil issues is because i dont shift a lot or run at high rpm's constantly because i have trans issues when i do.
Old Jul 18, 2010 | 10:26 PM
xlack's Avatar
xlack
i juz installed one a couple weeks ago!! 25 rows setrab, weiboy installed it for me.. awesome little product!!
Old Jul 20, 2010 | 10:26 PM
joo030879's Avatar
joo030879
Please post some pics
Old Jul 20, 2010 | 10:42 PM
Weiboy718's Avatar
Weiboy718
check out my installed pic's
https://www.myg37.com/forums/engine-...installed.html
4DRZ
May 29, 2024 09:28 AM
ill12will8
Oct 26, 2015 10:09 PM
4DRZ
Oct 2, 2015 09:54 AM
