MEDIA SHARE Intake, Exhaust, Engine, Forced-Induction & Drivetrain
My dyno 325whp
Old Aug 20, 2009 | 12:33 AM
  #46
808MIKE's Avatar
808MIKE
OK, changed from the Stafe 2+ map, to Cobbs Stock style map. Went for a drive, and did a few full throttle runs!
AFR's started at like 13.1-13.3 from begging of full throttle run, then as RPM climbed they dipped to like 12.8,...12.5...12.3...between 3500- maybe 6000RPM's. then at near redline it diped to maybe high 11.9's. then at closer redline i seen a 10.0 for a brief second! or could have abeen a 10.8? not sure as i let off the throttle right after that! So are those AFR's beeter than the Stage 2+ one i had before? This is on a G35 HR Sedan. I know i need a custom tune. but at least these AFR's look alot better than before! When I was wasting fuel more than making power!
Old Aug 20, 2009 | 12:34 AM
  #47
808MIKE's Avatar
808MIKE
Originally Posted by WhosUrBuddiee
Can any of them adjust timing?
Nope not yet!
Old Aug 20, 2009 | 02:04 AM
  #48
kaos2774's Avatar
kaos2774
Come on Cobb.. PLEASE give us some numbers
<a href="http://s197.photobucket.com/albums/aa5/Dan2774/?action=view&current=knowsyousuck.jpg" target="_blank"><img src="http://i197.photobucket.com/albums/aa5/Dan2774/knowsyousuck.jpg" border="0" alt="Photobucket"></a>
Old Aug 24, 2009 | 07:29 PM
  #49
rAvi665's Avatar
rAvi665
any1 at Cobb has anything to say???
Old Aug 30, 2009 | 04:31 PM
  #50
tristan1334's Avatar
tristan1334
Originally Posted by chamelieon
cobb's "stock style map"...
What software did you use to raise the rpm on "stock style" map?
Old Aug 30, 2009 | 05:10 PM
  #51
Seer's Avatar
Seer
ugh no... to make the most power NA, you want your open throttle AFR at about 13.0
Old Aug 31, 2009 | 12:23 AM
  #52
Nickkg37s's Avatar
Nickkg37s
So to get good power gains out of the accessport what your suppose to do is upload the stock map that comes with it right? Or should you just set it to stage 2 first then switch back to the stock style? Assuming that you have stage 2 mods, such as intake,hfc, and catback. Am I right here or not understanding?
Old Aug 31, 2009 | 01:42 AM
  #53
chamelieon's Avatar
chamelieon
stage 2 maps just seems to dump 15% more fuel but does nothing else but overload the car with too much fuel which will decrease power and waste a ton of gas for no reason. as of right now stay with the "stock style map"
Old Aug 31, 2009 | 01:46 AM
  #54
chamelieon's Avatar
chamelieon
not entirely true, the best NA horsepower gain is usually around 13.2 air to fuel mixture, but our V Motors make the best torque with a richer mixture. so in short every motor is different and may require leaner or richer. there is no magic target air fuel mixture.
Old Aug 31, 2009 | 01:55 AM
  #55
TJHG37S's Avatar
TJHG37S
chamelieion, what about the stage 1 map? i'm running that now with Injen CAI and Invidia exhaust but wondering if stock-style is better?
Old Aug 31, 2009 | 02:12 AM
  #56
chamelieon's Avatar
chamelieon
unfortunately even stage 1 map is a FAIL! .. stock style > everything.
Old Aug 31, 2009 | 02:17 AM
  #57
chamelieon's Avatar
chamelieon
please refer to this thread.
https://www.myg37.com/forums/engine-...xperience.html
Old Aug 31, 2009 | 06:35 AM
  #58
Seer's Avatar
Seer
actually if you want to get even more technical... an NA internal combustion motor pretty much works the same throughout the entire spectrum.
You want it slightly richer at peak torque, then lean at peak hp.
EX: 12.7:1 to peak torque, and 13.0:1 at peak hp.
I've built a few 800hp+ motors before, na and FI. FI obviously you want to go way richer.
Old Sep 7, 2009 | 12:35 PM
  #59
tristan1334
I'm using stock style and raised my rpm up 500. I'm thinking of changing the throttle/pedal positioning. Why is that it's only giving us 70% on WOT?
I'm using the ATR and I'm thinking of slightly increasing the throttle plate positioning to 5%. Any suggestion on this?
Old Sep 7, 2009 | 12:58 PM
  #60
Q8y_drifter's Avatar
Q8y_drifter
Can you elaborate on the 70% throttle at WOT?
