HI I'm new. Want to mod. But need help.
I just bought a new automatic g37 journey coupe. I've had it for a few months and I'm loving every bit of it. The only thing in pretty sad about is the underwhelming sound. I would like it to sound like...
https://youtu.be/W3i9ITjVQYc but I still need an exhaust because it's illegal to not have one in the US.
uhhh also will this be too rice? Will I have to buy a brake set of intake first?
Oh and also I am pretty new to car culture and the car scene so go easy on me. I think there is something called drone? I heard it gives you a headache when you're cruising. Is there an exhaust that takes out drone but can still make it sound like the link I gave?
Welcome to the forum. Google is your best friend at this moment, and myG37.com is your second best friend. Now, head over the G37 Coupe Section under GSPOT, and read the exhaust thread as well as head over the exhaust thread section under tech area.
There's plenty of information about this car, as well as exhausts, as this car is a 10 year old car.
Overall, congratulations on the G and good luck on finding the perfect mods.
There’s a number of exhausts that are louder and will give you more sound without drone. Exhaust drone is a persistent low pitched hum that some systems have at certain rpm. Motordyne is an great system that roars under heavy throttle, sounds low, mellow, and throaty, but doesn’t drone. It’s fantastic but it’s more expensive than some of the lower end stuff.
Meisterschaft is another too notch choice but it’s also expensive.
Welcome!
They others have said it already, so use the internet to your advantage and do some searching. I'm certain you'll find what you're looking for.
Advice:
The two things that will increase the sound of your car are the intake and exhaust.
Intakes are (generally) cheaper, but make less of a difference in performance/sound. I'd recommend doing some searching for what would work for your needs. The two most common routes people here take are either a full cold air intake system OR replacing the stock paper air filters with high-flow aftermarket ones plus installing high-flow intake tubes like these.
Exhaust is a whole other animal. There are a bunch of options that can fit most budgets, ranging from a muffler replacement to a full header/cat/midpipe/muffler replacement. Infiniti makes a nice "Sport Accessory Muffler" that I've heard no complaints about, but it's expensive because it's from Infiniti. High-flow catalytic converters will give you the most performance gain of any exhaust modifications, but they'll also be expensive. You can find cheap aftermarket muffler replacements on eBay if you're only after sound, but you generally get what you pay for...
Good Luck!
Advice:
Good Luck!
EuroG37
27
Oct 19, 2010 11:18 PM
GodWhomIsMike
Jun 3, 2008 04:29 PM
NyC Driven
Buying & Leasing
Mar 18, 2008 07:51 PM
