Recommendations for Intakes
Old Nov 9, 2017 | 09:37 AM
jrb55gh's Avatar
jrb55gh
For what its worth. My 370 has the stock intake. I measured the vacuum at 7300 rpm full throttle in the upper intake plenum with a stock replacement Napa gold air filter at 17mm hg. The vacuum dropped to 15mm hg with the R2C black hex filters. These hi flow filters offer less pressure loss in the intake. The only drawback to hi flow filters is the lower filtering efficiencies resulting in more dirt ingested into the engine. Good stock air filters have filtering efficiencies in the 98-99% range. The hi flows have filtering efficiencies in the mid to low 90's. More dirt = faster ring wear.
Old Nov 9, 2017 | 11:23 AM
DeanMachine's Avatar
DeanMachine
That's good info to have in general. Is the filter efficiency proportion vs. stock the same with conical on a CAI as well? Seems like it would be. Filter efficiency vs. flow rate is a natural trade-off.
Old Nov 9, 2017 | 09:03 PM
jrb55gh's Avatar
jrb55gh
Dean... You are correct In every test I have seen the general trend is:The pressure drop decreases as the filtering efficiency decreases. The way to get low pressure drop and high filtering efficiency is to use high efficiency media and increase the filter area.
Old Nov 10, 2017 | 07:01 PM
MJaga's Avatar
MJaga
Beware of R2C. I needed to order replacement filters and as of 6 weeks ago the vendors on here do not sell them because R2C was not shipping orders timely.
I ordered direct thru R2C and over a month later, still nothing. I couldn't even get them to reply with an order status. I eventually had to file a claim via paypal and R2C refunded me almost instantly, no reason or explanation noted.
I have had my R2C CAI for about 3 years and there is already significant rust on the heat shields and cracking in the tubes. Granted, I don't keep my car showcar clean, but I am now going to just revert back to stock intakes.
I have used K&N intakes on vehicles in the past with no issues, though I can't speak to them on G37's.
Old Nov 10, 2017 | 07:07 PM
DeanMachine
Thanks for the heads up - I just have the R2C drop-ins at this point. Got them about a week after I ordered. Either I got super lucky or it's only a problem with the conical/CAI.
Old Nov 10, 2017 | 07:15 PM
MJaga's Avatar
MJaga
I stand corrected. As I sent that I received a delivery of the conical filters from R2C. So while it did take over a month to receive, they did come and seem to be high quality.
Old Nov 11, 2017 | 10:08 AM
Victory's Avatar
Victory
There have been dyno tests showing that drop in panels offer roughly the same performance as full intake systems on this car. Gains are mainly above 6000rpm.
I'd just do drop ins and remove the silencers or, if you want to go for looks, add some silicone tubes. The factory intake is very well designed and the dual intake setup provides plenty of air for this engine in factory format.
Old Dec 4, 2017 | 12:00 PM
airanp's Avatar
airanp
I just put K&N drop ins in my car over the weekend. It does sound a tiny bit better but nothing big. Butt dyno told me it performed better too...Jk. I am curious about the silencers. Could you tell me where they are and maybe a pic. I have' really looked to much myself but I am about 100,000 miles so I am going to change the plugs and clean the throttle bodies so I would just take them out at the same time.
Old Dec 8, 2017 | 06:59 PM
Kpmikey808's Avatar
Kpmikey808
Admin tuning by Saul & uprev
I follow tuner Saul & moncef with admin tuning
these numbers don’t lie - 308whp with just admin intake & uprev tune
gonna try & get my car dynoed before & after with these intakes
Huge gains
Old Dec 12, 2017 | 12:54 PM
future62's Avatar
future62
Is there a way to make the stock intakes louder? That is all I really want out of an intake, especially considering some of them actually lose power.
Has anyone measured IATs on the K&N Typhoon? I've seen some Ebay replicas with the heat shield and I'd like to know if they actually work. Also do they need the stock hood insulation to make a full seal? I took mine out for more intake sound
