What causes exhaust tips to be crooked/uneven?
Old Feb 19, 2013 | 04:15 PM
Dr.Pat's Avatar
Dr.Pat
I've seen pictures of uneven/crooked exhaust tips on cars with aftermarket exhaust systems. What causes the tips to be uneven? Does it have to do with the exhaust system (poor build quality and fit)...does it have to do with poor installation and alignment...is there one specific part of the exhaust system that is responsible for knocking things out of whack when its changed? I'd assume that you're less likely to have this problem if you're just installing an axle-back system as opposed to a full CBE (assuming your factory setup was straight).
Old Feb 19, 2013 | 04:45 PM
Most aftermarket systems need to be adjusted somewhat to get the tips straight and even. Some require a little bending or tweaking of the exhaust hangers on the car or on the exhaust or both. Some are poorly manufactured or have poor QC and won't be straight without a lot of modification. Some have cosmetic tips that slip onto the ends of the tail pipes and are held in place by a set screw. It can be a bit tough to get them perfectly straight especially if you are doing the adjusting by yourself and have nobody to eyeball it while you make adjustments. Some fit dead solid perfect right out of the box.
Old Feb 19, 2013 | 04:57 PM
Dr.Pat's Avatar
Dr.Pat
Are there certain systems that have this reputation?
DeamonG37s's Avatar
DeamonG37s
Buy authentic JDM parts, cost more but quality is not a issue or fitment. Pretty much exhausts that's cost more money and do research before you buy theirs reviews/dynos/comparisons of every exhaust system out their on this site for our cars.
Old Feb 19, 2013 | 05:03 PM
DeamonG37s's Avatar
DeamonG37s
Research the one you want and you will get ur answer. I don't wanna bash an exhaust I don't have, but read up on it you will see ppls concerns with certain brands.
Old Feb 19, 2013 | 06:18 PM
My Tanabe did. So did my Invidia Q300. 100% perfect fit on both with no adjustments whatsoever.
Old Feb 19, 2013 | 06:28 PM
JSolo's Avatar
JSolo
Just say no!!!!!
My Q300 tips were a bit too close for my comfort to the rear bumper (1/4"?). I used some flat washers to build up a slight distance. Every car is ever so slightly different. ymmv
Old Feb 25, 2013 | 12:27 PM
BosMaSwaG37's Avatar
BosMaSwaG37
To piggy back off of this, my experience with Tanabe was slightly different. The performance and sound was great and I'm a big fan of them in that regard. However, I did have fitment and muffler alignment issues. I had to trim down the right side of the transmission bracket in order to prevent the Y-pipe from rubbing onto it and it was more than a bitch to get the mufflers aligned. I eventually got them aligned but it took a lotof force. Nothing about it was simply...I actaully needed a second set of hands. I initially thought it was the part of the process but after installing my third CBE system I am convinced that the issue with was Tanabe. I just installed FI CBE and had zero alignment issues. I had to make other painless modifications, such as removing a heat shield that really isn't needed with this muffler design anyways but the alignment was perfect and spot on. FYI, experienced muffler alignment issues with two different sets of Tanabe CBE's
Old Feb 25, 2013 | 01:09 PM
IPL 370GT's Avatar
IPL 370GT
Just adjust the exhaust hangers.
Old Feb 25, 2013 | 01:25 PM
P Casey's Avatar
P Casey
I had to adjust my HKS and they never really were 100% even.
Old Feb 25, 2013 | 01:31 PM
For clarification, the Tanabe I installed wasn't CBE, just the mufflers only. Perfectly aligned without any manipulation or having to adjust the hangers.
Old Jul 10, 2014 | 01:58 AM
Mazaki's Avatar
Mazaki
Resurrecting the thread. Just installed my Tanabe Mid and Y-pipe today with a buddy using a lift. The Tanabe mufflers were already installed, and aligned perfectly when on the stock mid-pipe. Now with the Tanabe mid-pipe, the driver's side muffler is out of alignment. I think later I'll have to get under there and see if I can adjust it.
Ugh. I was so happy when I got my Tanabe mufflers and the alignment was spot-on (unlike the factory exhaust). Now when finally upgrading to catback, I get an old problem rearing its ugly head on an exhaust that is supposed to be top-notch.
Old Jul 13, 2014 | 03:35 AM
conkus805's Avatar
conkus805
Just for reference, my ark grip fit perfectly. No bending, or added washers to make it straight. Guess I got lucky.
gipl
Oct 20, 2015 11:57 PM
TheIvoryG
Sep 23, 2015 02:06 AM
gipl
Sep 15, 2015 08:59 PM
slotterjordan
Sep 8, 2015 10:29 PM
