exhaust leak from art pipes
alright well im having an issue with my art pipes that apparently has happened since i installed them but didnt notice untill now. basically i have a leak from both art pipes from the sides of the header to art pipe connection. origionaly i had just siliconed the connection but since i found the leak i ordered the z1 motorsports metal gaskets and i still have the same leaks from the same locations. has anyone had a similar issue or fixed this issue? and yes i have contacted tony and he wont warranty them because they where bought used.
Man sorry to hear that, I'm sure you've contact the previous owner about your leakage problem first? Did he/she run across this issue as you described?
Have you tried a belt sander or something equivalent to smooth/rid out the imperfections causing the leaks. Or maybe you didn't apply enough silicone on it nor let it cure well enough
The best way to seal a exhaust leak is with silicone type gaskets so which one are you using? I know this silicone works very well for high temp applications Gasket Makers : Permatex® Ultra Copper® Maximum Temperature RTV Silicone Gasket Maker
GL
GL
I can second the leaks on GET_SOME'S art pipes. You can not only feel the leak but you can see it, also it is throwing his o2 sensors off and the car smokes when he gets on the gas. I've personally reset his ecu 3 times because of the sensor throwing a code.
From our experience. The best way to go about this is to utilize the thick OEM gaskets if the testpipes have an extension to it, in order to hold the OEM gasket. Alternatively,
you can heat wrap that area which also had good results in the past.
I just installed my ART pipes on my G. it's paired up with the tomei exhaust and now my exhaust note is really loud in the low rpms and then quiets down after 3k rpm's. idk what it can be, can it possibly be an exhaust leak? someone help mer
