Help! Stillen gen 3 humming/buzzing noise
Old Jun 5, 2012 | 09:50 AM
roksolid's Avatar
roksolid
Hi all.
I just installed a stillen gen 3 intake last week on my G37S sedan. The guys that installed it didnt really know what they were doing.
The buzzing/humming sound is mostly apparent at low RPM 1-3K, it sounds like it is coming from the left front side of the engine (maybe intake).
The intake also makes contact with the wheel base and rattles when in reverse.
The thing is I had some intakes on my old car and never had more noise unless I really stepped on the gas.
I dont have any other mods other than a grounding kit, which I've had for a while with no issues.
So, Im wondering are these sounds natural or were my intakes installed incorrectly.
Any input would be much appreciated.
Thanks.
Old Jun 5, 2012 | 10:11 AM
GET_SOME's Avatar
GET_SOME
a humming or buzzing i would relate with the metal intake pipe vibrating against something
Old Jun 5, 2012 | 10:30 AM
1cleanG's Avatar
1cleanG
NextLevel Performance
exactly correct ^^ Check around where the piping goes and make sure its not rubbing on anything
Old Jun 5, 2012 | 11:06 AM
roksolid's Avatar
roksolid
Thanks for the input guys.
The sound sounds more like a supercharger blowoff valve or something of that sort. Sounds like leaking air.
Ill try and put some cloth between the contact points and see if that helps.
Old Jun 5, 2012 | 01:31 PM
ANMVQ's Avatar
ANMVQ
The Cloth will probaly move, Didnt the kit come with rubber pads for that area, I know when my dealer installed mine they had rubber pads on the Rad support where the intake pipes went.
Old Jun 8, 2012 | 01:31 AM
roksolid's Avatar
roksolid
No. It didnt come with any rubber pads, do they suppose to come with some?
I added some padding between the pipe and wheel base where it touches, But that humming noise is still there, sounds like a turbo blowoff valve but to a lower extent.
Anyone experience similar issues?
Old Jun 8, 2012 | 09:59 AM
awais's Avatar
awais
I get some noise between 1700-2200rpm. I don't think it's exactly what you are describing. It's more like a very deep growl/buzz.
Old Jun 18, 2012 | 09:45 PM
trcb777's Avatar
trcb777
Does it make the noise in neutral?
beng37s
Dec 8, 2019 01:21 PM
si_driver
Oct 1, 2015 09:53 AM
hamkha1ebay
Sep 28, 2015 02:38 PM
SON415
Sep 28, 2015 05:49 AM
