Intake installed, strange engine behavior.
Old May 26, 2011 | 07:15 PM
areyoojordan's Avatar
areyoojordan
I just got my short ram intakes installed, they sound great! Love the growl and sound difference at high rpms. But strangely, when i hit the gas pretty hard at lower speeds ~15-20 mph, the engine engages, then pauses/bucks for a quick moment, then engages again. Its almost as if the engine dies out completely for a second. This started happening as soon as I installed and took it for a spin. Anyone know what the problem might be?
Old May 26, 2011 | 08:14 PM
Doggy's Avatar
Doggy
Like it's bogging down?
Old May 26, 2011 | 08:57 PM
myk1013's Avatar
myk1013
check your MAF sensors.
Old May 26, 2011 | 09:16 PM
_ant_'s Avatar
_ant_
^yeah i agree check the MAF's
Old May 26, 2011 | 09:26 PM
123u's Avatar
123u
disconnected the battery for a few hours then it will reset the ECU, everything should be alright i hope and make sure there is no water in the MAF sensors, and make sure everything installed correctly.
Old May 27, 2011 | 04:53 AM
tWistedMissiOn's Avatar
tWistedMissiOn
+1 for the MAF, pretty much everyone who has similar kind of problems from intakes are from the MAF sensors
Old May 27, 2011 | 12:57 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
check all your hoses again you might have a slight leak
Old Jun 2, 2011 | 10:31 AM
stormgate's Avatar
stormgate
check that you didn't install the mafs backwards. the thin side that has the "hole" should be facing the filter. wish i had a pic of the maf to explain it better.
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
FLQ50s
Sep 16, 2015 10:07 PM
Sway_NV
Sep 10, 2015 01:51 AM
