Quick question about Injen CAI
Old Aug 17, 2010 | 02:02 PM
  #31
hispeed-lowdrag's Avatar
hispeed-lowdrag
well said Danny, thanks for correcting the misconception
Originally Posted by ucla bruin
Theory: Injen CAI suffocates the filters because the poor filter location. No access to air.
Test: I dynoed my car with Injen CAI with the bumper off so the filters can breathe "fresh" air. Then dynoed it again with the bumper on.
Result: The difference was 1-2hp.
Note: You can open up vents and stuff to expose "fresh" air to the filters but risk the chance of more road debris + water to get to your filter. IMHO, it is not worth that extra 1-2hp.
Another note: I brought up the question about suffocating the filters to Injen's R&D director. What I gathered is that the filters are not suffocated because you can pull air from all around. From the lower + upper grill and the hole on the bottom near the under carriage (check it out). Fact is there's cool air all around and gets pulled when needed. The filter doesn't need to be blasted with open air, which if done incorrectly, can produce a dangerous AF ratio due to leaning. Also, the filters are located furthest away from the injen or any other heat source.
The intuitive but common misconception is that the filters need to be exposed, out in the open for it to get cool air or fresh air. But this is simply not true.
Old Aug 17, 2010 | 11:00 PM
  #32
cvt's Avatar
cvt
good input by ucla bruin.
that is why i don't understand why short rams have heat shields...what exactly are the shields blocking? the filters are right up on the engine bay and trapped where all the hot air is...LOL.
warm air rises...cool air sinks....very black and white.
Old Aug 17, 2010 | 11:24 PM
  #33
yogregb's Avatar
yogregb
Well I was going to leave this one be......but... I have to disagree Danny, please know I respect your opinion. I think what your forgetting is that on the dyno, your car is not at speed, therefore your discounting the ram air effect, which makes this intake system perform at peak, thus giving you more then 2 hp difference. I don't know about your car ,but My 09' model has a plastic partition in that area blocking off the lower grill. Your right, there is a small drain hole at the bottom of the plastic wheel liner, but that's it on MY car, I know, I've been in there enough! And I agree the filters are farther away from eng heat in general. The bottom line for me, is, I know I improved my intake system simply by giving it a 2 1/2 vent and as far as af ratio, that's the MAF sensors job. Overall I think this intake is a worthwhile mod, just for looks and sound, let alone hp gains..my 2 cents...
Sooo... when are you going to do my headlights and I'll do your fogs??
Old Aug 17, 2010 | 11:26 PM
  #34
Frankyg37s's Avatar
Frankyg37s
this is why im scared of k&n filter no offence to anyone http://www.bobistheoilguy.com/airfilter/airtest1.htm
Old Aug 18, 2010 | 01:51 AM
  #35
ucla bruin's Avatar
ucla bruin
Haha. I like the idea of opening up the vent area and I've seen other members getting improvements from the mod. I don't doubt its affect and I would love to have that option. But my point was only to address the fact that the filters does pull cool air from the surrounding. There is a plastic flap but I'm sure the filters are not choking down there. The OEM intake inlet also provide a source of "fresh" air. More importantly, the filters are directed away from heat source.
Also, for what it's worth, when I dynoed, we simulated the wind effect by putting blower fans in front of the car for all the runs.
__________________
Old Aug 18, 2010 | 09:19 AM
  #36
hispeed-lowdrag
A dyno would be worthless if you couldn't simulate "at speed." that's why every single dyno uses a huge blower to push air through the front of the car...so no, that wasn't forgotten.
Also, I know for a fact that middle grille is completely open, there's no plastic sealing it off. There's mesh for the bottom grille, but it's completely open from front to back.
Not trying to be a d1ck, just saying that plenty of fresh air circulates down there
Old Aug 20, 2010 | 03:32 PM
  #37
TheLocNar's Avatar
TheLocNar
Uhh... pull cold air from exactly where, because that area where the filter is sealed off from the front lower and upper grills
It's not air tight.
Old Aug 20, 2010 | 06:11 PM
  #38
Q8y_drifter's Avatar
Q8y_drifter
Actually the sides are sealed off to divert air towards the radiator and P/S cooler. take a look into the lower grille in the middle and look inside towards the left and right side. There's a plastic piece on each side that blocks air from entering the sides, since there's nothing to cool anyway. I actually took them off, redyno'd and made another 4whp. That's before I even drilled holes into the fake mesh on the journey bumper. I dunno how accurate that is but I made several runs before and after and that was the difference between each average. I have the Injen CAI btw.
EDIT: Look at the pics voltic posted on post #18. The first pic shows the 2 plastic i dunno what you call them on each side. When the bumper is reinstalled, those pieces block a lot of the air that is meant to go thru from the bottom center grille.
Old Aug 20, 2010 | 07:27 PM
  #39
Frankyg37s's Avatar
Frankyg37s
theres maybe is a diff in the sport and non sport bumper????Q8Y how hard is it to remove those plastic things you speak of and does the sport bumper have them too????
Old Aug 20, 2010 | 07:38 PM
  #40
Q8y_drifter
The drivers side piece is very easy. It's just clipped into place. Literally takes 5 seconds to remove.
The passenger side however has the P/S cooler lines going right through it. You'll need to unhook the P/S lines, unclip the piece off and then reinstall the lines to the cooler. I can't remember if there's any bolts to remove but I don't think there is.
My car is an HR sedan with a journey bumper. Voltic has a VHR coupe with a sport bumper and we both have those pieces. Doesn't matter what car it is I guess.
Old Aug 20, 2010 | 10:05 PM
  #41
yogregb's Avatar
yogregb
[quote=Q8y_drifter;2955700]Actually the sides are sealed off to divert air towards the radiator and P/S cooler. take a look into the lower grille in the middle and look inside towards the left and right side. There's a plastic piece on each side that blocks air from entering the sides, since there's nothing to cool anyway. I actually took them off, redyno'd and made another 4whp. That's before I even drilled holes into the fake mesh on the journey bumper. I dunno how accurate that is but I made several runs before and after and that was the difference between each average. I have the Injen CAI btw.
EDIT: Look at the pics voltic posted on post #18. The first pic shows the 2 plastic i dunno what you call them on each side. When the bumper is reinstalled, those pieces block a lot of the air that is meant to go thru from the bottom center grille.[/quote
True that!! Thanks for posting this... it was my experence too
Old Aug 20, 2010 | 10:18 PM
  #42
yogregb's Avatar
yogregb
Originally Posted by efuseakay
It's not air tight.
It may not be air tight, but if you stuck your head in there, you'd have trouble breathing..lol...
Old Aug 20, 2010 | 10:45 PM
  #43
Q8y_drifter
yogregb, that looks really clean! great job. I didn't do much to mine as the journey bumper I have is only a temp until I get a sport bumper. I simply drilled out all the fake holes with a 6mm drill tip and removed those plastic pieces. I was planning on doing the same thing you did with the sport bumper and add fine mesh from the inside to protect it from debris.
Old Aug 20, 2010 | 10:55 PM
  #44
cvt's Avatar
cvt
Can you post these dynos? I'd like to see the gains throughout the curve...any a/f changes?
Old Aug 21, 2010 | 12:03 AM
  #45
Q8y_drifter
I don't have the 2 runs I did before I removed the pieces, just the 3 runs I did afterwards. I didn't think of printing them out. I just wanted the numbers that made max power at the time :/
Not much help but here they are.
252.66whp
253.21whp
254.12whp
Car is a 5AT HR sedan
