Need help with Stillen HFC's
Old Nov 30, 2008 | 06:44 PM
Skyline-LEXY's Avatar
Skyline-LEXY
^^ u can get the three point gasket at ur dealership for 14$ each
Old Nov 30, 2008 | 08:46 PM
kaos2774's Avatar
kaos2774
^^That would be sick if that's all I need. Thank's for the help
Old Nov 30, 2008 | 09:21 PM
G37Rider92649's Avatar
G37Rider92649
were you the one at amplified yesturday? I was the asian guy that tried to help you a bit haha, i hope you solve this problem, this's just another reason why I dont want hfc anymore
Old Nov 30, 2008 | 10:10 PM
BerkTechnology's Avatar
BerkTechnology
Originally Posted by kaos2774
When I clear the SES light with my Cobb AP the car runs great but when it comes back on the car seems to louse some power off the line.
You might have another code there. If the car noticably loses power when you get the CEL light, it's not the P0420 & P0430. See if you can pull the code.
i had P2A00,P2A03(a/f ratio issue) b/c of the leakage befor the HFC since
i didnt have a gasket in there.
checked your web and couldnt find three point gasket for flange to the engine side.
If you have it PM me please.
Will send you a PM for the gaskets. Those codes are from the front O2 sensors (the ones in the header). Double check to make sure that those are the codes. It sounds like damaged O2 sensors from the install (impact tools).
Nissan doesn't make them. We have them custom made for our HFC's.
Old Nov 30, 2008 | 10:51 PM
Skyline-LEXY
^^ i picked up my gasket from South Bay Infiniti for Stillen HFC.
Old Nov 30, 2008 | 10:54 PM
shumby's Avatar
shumby
^^^^ hmmmmmm seems Berk is wrong again.
Old Nov 30, 2008 | 11:21 PM
BerkTechnology
For the header/cat flange? It's a crush ring. I'm talking about a flat gasket.
Old Dec 1, 2008 | 02:18 AM
kaos2774's Avatar
kaos2774
Lets not tern this in to a Berks bashing thread. You can get stock crush ring and the gaskets at the dealership. I know because I have all ready replaced them. I hope Berks is right about the non-foulers. the code I'm getting on my Cobb AP is PO420 and 430 I need to find out if that is a air leak or to much air going through them. I'm going to need to get them inspected.
Old Dec 1, 2008 | 02:31 AM
jungwoo0622's Avatar
jungwoo0622
You and me has almost same set up
tanabe spring, injen intake, HKS exhaust, HFC,cobb will pick up monday.
You had a reak at the hfc?
what was your code?
After you installed gasket then code was gone?
Old Dec 1, 2008 | 11:40 AM
kaos2774's Avatar
kaos2774
what was your code?
I have a SES light on I had new gaskets installed and I still have the SES light on. the code off my AP is PO0420
Old Dec 1, 2008 | 01:22 PM
kaos2774's Avatar
kaos2774
Ya that was me. I think you were right on about fixing the problem. If its a air problem and not a leak
Old Dec 1, 2008 | 07:17 PM
Skyline-LEXY
Leak will be different code. 0420 and 0430 is the HFC O2 sensor.
btw I was thinking... if we relearn the IDEL AIR Vol... would that work? there was a TSB about replacing ECM and it mentions about ACCELERATOR PEDAL & THROTTLE VALVE CLOSED POSITION LEARNING and IDEL AIR VOL LEARNING.
beng37s
Dec 8, 2019 01:21 PM
hamkha1ebay
Oct 3, 2015 02:55 PM
hamkha1ebay
Sep 28, 2015 02:38 PM
SON415
Sep 28, 2015 05:49 AM
Crespo
Sep 25, 2015 11:16 PM
