Caution O2 sensor removal
Old May 17, 2008 | 08:16 AM
chucky's Avatar
chucky
Be careful when removing the O2 sensors. I had one that was extremely hard to get out. I used all the normal good mechanic procedures to no avail, got it half way out an noticed it was installed tilted to one side. Now it will not come out period! I'm taking the catalic converter with the improperly installed O2 sensor to the dealers and hoping they will see the problem as improperly installed at the factory. The other one was hard to get out also and when I inspected it the threads where gawled. Appears it was installed without using anti-seize compound. Lesson learned.
Old Jan 30, 2011 | 05:18 PM
Steveo47's Avatar
Steveo47
with the power invested in me by myg37.com i bring this thread to LIFE!!
Anyways, any advice for removing those o2 sensors, a technique? i plan on attempting to instal my test pipes again and i dont want to break one!
Old Jan 30, 2011 | 09:00 PM
Obvis07's Avatar
Obvis07
O2 sensor remover. do not use anything else. will likely mess up the thread. their cheap just go on ebay or something. and passenger side O2 is tighter than the driver side for GnZs
Old Jan 30, 2011 | 09:03 PM
Modme's Avatar
Modme
Soak it with PB blaster for a good 20 minutes before removing it. I did that and came out smooth.
Old Jan 30, 2011 | 09:04 PM
Steveo47's Avatar
Steveo47
I couldn't just use a wrench?
Old Jan 30, 2011 | 09:07 PM
Modme's Avatar
Modme
You cant. Look at how long a O2 sensor is.
You can't fit a socket wrench around it. If you're planning to use a regular wrench, I'd think again. You'll more than likely to strip it.
If you have an autozone around you, you can rent the O2 remover tool for free.
It looks like this:
Old Feb 7, 2011 | 01:48 PM
Steveo47's Avatar
Steveo47
I bought one for 8 bucks. Great sockets!
139
Jul 12, 2025 09:56 AM
finagle69
46
Aug 27, 2017 06:38 PM
SPDCRZ
Dec 29, 2013 02:38 AM
inTgr8r
125
Sep 27, 2013 05:56 PM
weave
Intake and Exhaust
16
Dec 5, 2008 06:25 PM
