Tanabe Exhaust Clip for G37
Old Jan 23, 2008 | 11:44 PM
  #76
RedG37SNC's Avatar
RedG37SNC
Originally Posted by GiGGaplease
i think its going to be around 1k, the 03-07 g was 980. how big are the tanabe tips? fast intentions is like 2.5 inches.
There's more to the G35's exhaust. The G37's just axle back and should be less.. I'm hoping around $700.
Old Jan 24, 2008 | 07:15 AM
  #77
GiGGaplease's Avatar
GiGGaplease
what does a y pipe does to the car? more air flow?
Old Jan 24, 2008 | 09:30 AM
  #78
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Ya 1G is a lot of money for just an axle back system.
Old Jan 24, 2008 | 11:06 AM
  #79
]\[ /-\ ]\/['s Avatar
wat y pipe? this car has true duals stock
Old Jan 24, 2008 | 11:19 PM
  #80
RYs06MT's Avatar
RYs06MT
I'm hoping it's not that much. I will ask about a group buy as soon as they post a price; when I spoke with Tanabe early this week there was still no release date.
Old Jan 24, 2008 | 11:30 PM
  #81
bboysteele's Avatar
bboysteele
^^When are you going to get your car dynoed? Just want to see what numbers you are putting up even though we don't have the numbers you had before the install.
Old Jan 25, 2008 | 12:40 AM
  #82
RYs06MT's Avatar
RYs06MT
Well I decided to just hold off because I have no accurate way of knowing the gains. Tanabe did dyno my car and I posted the gains they told me 8hp/7tq. (I was not given a copy of the dyno sheet for privacy reasons and the kit wasn't even in production at the time).
I figured I'd wait till they release the kit, then I'm sure they will post their dyno chart. (Since I know it will be based on my car) I will then dyno my car and compare it to their before and after numbers because I will then know the stock power they are basing their gains off.
I figure that's the best way to help members out, unless you have a better idea?
Old Jan 25, 2008 | 09:58 AM
  #83
KAHBOOM's Avatar
KAHBOOM
8/7 certainly sounds reasonable considering the fact that FI got 11/8 with a cat back system. I just want to see the curve to make sure we are not losing down low with this system.
I am either going to get an intake, or exhaust but not both. I think that once you go with one or the other if you then try to add the oposite you don't get enough gains for your money to justify it (at least not for me). If you already have an intake then the 8/7 gains over stock turn into just 5/3 over your car with an intake in addition to needing an ECU reflash.
Old Jan 26, 2008 | 08:24 PM
  #84
RedG37SNC's Avatar
RedG37SNC
I'm in for a group buy on the Medalion Touring exhaust. I'm also interested in the Sustec Pro 5 active suspension, can you ask them if they plan to release a G37 version?
Old Jan 26, 2008 | 09:17 PM
  #85
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
^^^^^^is there a group buy coming up ?
Old Jan 27, 2008 | 09:56 AM
  #86
GiGGaplease
hopefully. if the price is right, around 600-800, i would most likely get the tanabe. if not i probably get the fast intentions.
Old Jan 27, 2008 | 11:29 AM
  #87
terrycs's Avatar
terrycs
8HP / 7Tq sounds a little ambitious for only an axle back. I've seen the G37 exhaust ... the tubing (which necks down to less than 2" at some spots) in the front section after the cats and the section with the resonators are what I believe really chokes down the flow and is where most of the power loss is.
I would better believe the numbers if you were actually there watching them do the pulls because there are too many ways to "tweak" the results. For example, are they comparing the true average of the runs or are they doing "best to worse" which is the best run with their cat back vs the worse run stock.
The thing about not getting the dyno sheet was a little fishy too. What could be so proprietary about it?
I have nothing against Tanabe, but as with any other manufaturer ... I'd prefer verification of the results by an independent source such as yourself.
IMO, one should first look objectively at the ratio of HP/$ to help decide if a mod is worth it. Then throw in the subjective stuff like sound quality, looks, etc.
Old Jan 27, 2008 | 11:53 AM
  #88
Originally Posted by terrycs
8HP / 7Tq sounds a little ambitious for only a cat back. I've seen the G37 exhaust ... the tubing (which necks down to less than 2" at some spots) in the front section after the cats and the section with the resonators are what I believe really chokes down the flow and is where most of the power loss is.
they're prolly waiting til closer to production ready b4 releasing dynos....btw, this is not a catback...just mufflers (axle back?)
Old Jan 27, 2008 | 12:08 PM
  #89
terrycs's Avatar
terrycs
oops my bad ... previous post corrected. Thanks!
slowbird
Aug 3, 2023 07:54 PM
Broski28
Feb 26, 2016 12:26 PM
xxg00w0
Aug 16, 2015 08:31 PM
