Intakes
Old Sep 25, 2007 | 01:37 AM
  #61
leeI35G35's Avatar
leeI35G35
Originally Posted by Volk350z
the map sensor placement is different.. if you use the 350Z HR intake you will be running too Rich..
I didn't get to hear it but they did record it and will post it up on youtube.com once is up I will link everyone...
Hey Volk, I have a question. This maybe for the fujita company (techs) but even if the 350z intakes fit and the car runs rich, couldn't you lean out the air fuel mixture with a Apex'i SAFC-II or VAFC?
I know on my old car, I would either run rich or lean based off of the type of power adder (bolt-on) that I added to the car. I would just get a dyno tune to lean out the mixture a little and would gain more whp. I would rather buy the 350z intakes that run rich and lean out the mixture for more whp (plus the intakes sit farther from the engine) than get the g37 intakes. A dyno tune wouldn't cost much and I already have a SAFC-II. For some reason I like the way the 350z intakes look.
I will call Fujita tomorrow and try to get some questions answered.
Old Sep 25, 2007 | 04:02 PM
  #62
Ahujadaddy's Avatar
Ahujadaddy
PERFORMANCE NISSAN or EVERYTHINGG35?
Anyone here recomend one over the other? Or both are reputable and good customer service?
Old Sep 25, 2007 | 05:18 PM
  #63
finagle69's Avatar
finagle69
i just received mine that was purchased through EverythingG35.com I'm installing tonight when i get home!!!
anyway, the guys over at EVERYTHING were courteous and knowledgable. very decently priced as well.
Old Sep 25, 2007 | 05:36 PM
  #64
likwidfuzion's Avatar
likwidfuzion
I ordered from EverythingG35 on Friday and my intakes are arriving tomorrow.
Old Sep 25, 2007 | 05:37 PM
  #65
Blk-G35's Avatar
Blk-G35
Finagle69,
How much did you pay for your Fujita intake and do you have any concern for sucking the hot air under the hood.
At least the Stillen intake comes with heat shields which should keep hot air getting into the intake.
Old Sep 25, 2007 | 06:38 PM
  #66
finagle69's Avatar
finagle69
Originally Posted by Blk-G35
Finagle69,
the heat shields will NOT keep hot air from getting in the intake. if hot air wants in, it gets in. i'm not concerned with it one bit. as you start moving, cooler outside air will go into the intakes.
i paid 307.80 plus 11 shipping. no tax as they are outside of CA.
EDIT: the Fujitas also happen to look 100x better than the Stillens.
Old Sep 25, 2007 | 08:06 PM
  #67
shumby's Avatar
shumby
are there HP and TQ numbers for the stillein?
Old Sep 25, 2007 | 08:18 PM
  #68
juicyj's Avatar
juicyj
heat shields
Finagle....
I disagree with what you said about heat shields not working.....I have seen that the HKS racing intakes truly prevent overheating in systems with their included heatshields, but I guess it also depends on the grill of the car and airflow. Still, how would you guys compare a Fujita intake with an Injen intake in general??? -jb
Old Sep 25, 2007 | 11:46 PM
  #69
Blk-G35's Avatar
Blk-G35
Finagle,
I'm also disagreed with your theory on hot air will find its way to the intake because the opening of the heat shield is only facing towards the front grill where the source of the cold air is.
I really don't like how most of the intake systems are testing under condition that you'll never sees during normal daily basis driving. Basically the hot air will be trapped under the hood and circulate around even with air flowing into the engine bay.
I've done short ram intake dyno on my 02 Civic SI while back and I saw about 8 ~ 10HP differences between hood open vs. closed with same fan blowing right in front of the bumper opening.
I believe that you'll expect to see huge difference between the intake w/o shield vs. w/shield when the hood is completely closed regarless of your car being moving or not.
Just my two cent and thanks for the pricing info for Fujita intake. Please let us know how it feel and few pictures would be nice too.
Old Sep 25, 2007 | 11:51 PM
  #70
likwidfuzion
You guys should read this:
Originally Posted by F5airRyan
When we do intake temp tests (Fujita intake), we notice about a 20 degree F increase while driving in the city. We see temps at stop lights rise to about +50-60 degrees above outside temp (this can differ between models but even on a turbocharged saturn sky redline, driving temps were very good). The intake temp is different than underhood temps. The G35, 37, 350Z, and most newer cars have temp readings in the sensor. While your car is moving, intake temps go way down and of course at a stop light, idle, or in traffice, temps do rise.
Old Sep 26, 2007 | 01:15 AM
  #71
]\[ /-\ ]\/['s Avatar
so best bet is to wait for a cold air intake?
Old Sep 26, 2007 | 01:29 AM
  #72
juicyj's Avatar
juicyj
cai
cais are nice, but u dont want to flood your engine. wait for some more ram air products to come out with more r&d to make ur decision....just my opinion.
Old Sep 26, 2007 | 01:35 AM
  #73
Blk-G35's Avatar
Blk-G35
But I haven't seen anyone posting dyno number with hood closed which simulates real daily driving environment and I bet Fujita guys are afraid of showing degradation in both HP&TQ with hood closed than stock intake system.
The fact of matter is that they saw higher intake temperature from their test and it will definitely degrade the overall power of the engine.
Old Oct 8, 2007 | 11:44 PM
  #74
cvt's Avatar
cvt
i've had headers, plenums, crankpulleys, intakes, exhausts...and the best performance mod was only after everything was put on and got it tuned with a reflash.
my Z with intake alone was just a noisemaker..
Old Oct 9, 2007 | 12:08 AM
  #75
vinnys coupe's Avatar
vinnys coupe
how much is the fujita giving to the wheel. whats better fujita or stillen. which gives more power. is it better to go with a stillen exhaust and intake rather then 2 diff brands, or does it not even matter??
