Upper hose coolant reservoir tank
Old Mar 15, 2023 | 04:33 PM
Nixonplumber's Avatar
Nixonplumber
Hello, I had to replace the grille today and in doing so I had to remove the 2 bolts holding the coolant reservoir tank. After getting the grille in somehow the top hose on the tank lost its connection to where ever it connects to and I can't find it. The bottom hose connects to a nozzle next to the radiator cap but where does the top hose connect to? Can someone show me a picture to easily find this I feel very dumb and lost right now.
LMFAO!
Old Mar 15, 2023 | 05:05 PM
ILM-NC G37S's Avatar
ILM-NC G37S
That is the overflow tube. It drains to the ground. There should be a "channel" between the two fans that this hose pops into.
Like this:
Old Mar 15, 2023 | 05:49 PM
Nixonplumber
Ahhhhhh! Thank You so much! I just put the hose in place and shut the hood. I saw those clips when I was trying to figure it out and now that makes sense. Those clips are not easy to wiggle the hose into, I used a screwdriver to pry one open a bit, and in the cold weather the plastic was brittle and it snapped but I go the bottom one in and it's snug.
Thanks, again!
Banshee
Dec 5, 2017 10:28 PM
Lucasmdemele
May 21, 2017 04:53 PM
Sweet Lew
Jan 11, 2016 03:17 PM
eksigned
General Tech Questions
Mar 7, 2011 11:13 AM
