Transmission help!
Transmission help!
Ok so for a while now I've been experiencing a weird thumping sound on acceleration when the car is cold..but recently I've noticed what feels like a transmission slip from 3rd to 4th under medium acceleration. The strange is that it only does it every once in a while and only it in auto but never when shifted manually. The car is currently at 110k and ATF was changed 2x at 75k and 1x at 90k. Any ideas or suggestions?
Rule number one: Don't change out the transmission fluids when you don't need it. It does more harm than good, especially if the gears and parts are worn out. I don't see why it had to be changed at 90k when it's a sealed automatic. How long have you been feeling this?
I don't buy into the sealed transmission stuff. I lookedi backaback and actually it was 75k 2x drain and fill and then did a 1x drain and fill at 90k and no issues at all..It has 110k on it now and just started the issues I listed...granted it's only "slipped" like 4 or 5 times total but I'm not sure what it is since I cannot get it to do it no matter how hard I drive it once it's warmed up or while shifting manual.
Lot's of talk about 3x d&f at 60-70k as PM. Definitely at 100k, since thats what mfg. calls "Lifetime". But from your logic, a fluid swap when you "need it" would more often than not be on a higher mileage/worn out trans, which is more harmful? Paradoxical
Would like to hear your thoughts and reasoning on this, and when you "need it"
Op: It sounds like something internally. If you’re slipping gears and no hear a thumping noise, I can only pray that you don’t end up stranded. Sounds like you either have low fluid levels, bad fluid (which I mentioned up above), or air in bubbles in the lines. The symptoms you mentioned are all signs of a failing transmission unless the mounts have gone out. If that is the case, I would still not cheap out and go ahead and repair the transmission.
to be very sporadic has happened maybe 4-5 times the last 3k miles..it absolutely could be the transmission failing but seems like it may be something else since it has never done it when manually shifted no matter how hard I drive it..I guess I'm trying to figure out why that's happening and what else it could be.
Ok so I drove around 300 miles the last couple of days in D, DS Auto and manual. I was only able to get it to "slip" or more like a flare when up shifting from 4th to 5th. It always happens while driving in auto D or DS but never not even once when I shift manually no matter how easy or hard I accelerate..Any ideas what this could be?
brevi
Aug 23, 2016 09:35 PM
FastG37xS6610
May 14, 2013 11:09 AM
