Code P0106/Throttle Body Clean
Old Feb 21, 2020 | 02:14 PM
robger99's Avatar
robger99
2011 G37 CoupeX. 68,000 miles. Attempted to clean throttle bodies to try to fix error code P0106 Manifold Absolute Pressure/Baro Sensor Range/Performance. Map sensor replaced by dealer when I purchased the car 1000 miles ago. Unable to remove bottom allen bolts on throttle bodies using allen wrench. Tried Pb blaster with no success. Any advice appreciated.
Old Feb 22, 2020 | 09:37 AM
SonicVQ's Avatar
SonicVQ
There is a technical service bulletin (TSB) for your car that corrects a false P0106.
Details can be viewed here: https://infinitig37.com/TSB/ITB12-026a.pdf
Good luck!
Old Feb 23, 2020 | 05:02 PM
Surfnazi's Avatar
Surfnazi
Try to remove them after the pb soaked over night and while its cold
Old Apr 25, 2022 | 07:07 PM
bedhead's Avatar
bedhead
Good luck!
ahhh...you knew there was a TSB...thanks for making me work a little harder to find it.
Old Apr 25, 2022 | 08:54 PM
SonicVQ's Avatar
SonicVQ
WTF? Comments like this make me wonder why do I waste my time trying to help others.
Next time you have a problem, I hope someone else will give you a direct link.
firstGride
Jul 11, 2025 09:43 AM
haleakalag
14
Jul 26, 2019 04:22 PM
JakeG37
Apr 20, 2018 12:05 PM
venmichaels
12
Nov 27, 2017 04:40 PM
LukeJS
May 3, 2017 10:11 PM
