P2135 error code throttle position sensor
Old Jul 4, 2016 | 12:23 AM
firstGride's Avatar
firstGride
Exclamation P2135 error code throttle position sensor
So I was driving my car and I was slowing down because I was coming to a light. The light turned green before I stopped and while I was rolling stepped on the gas and nothing happened... I floored it but still nothing. The service engine soon light came on. The car was still rolling so I pulled into a parking lot and turned the car off. I turned the car back on, the light was still on but the car was operating properly all the way home. The car has done this multiple times since then. I took the car to autozone and I got Error code P2135 Throttle position sensor range/performance. "Code P2135 indicates that with the ignition on the PCM detected the difference between the throttle/ pedal position sensor / switch A signal and the throttle/ pedal position sensor/ switch B signal was greater than the maximum allowable value."
Please help. I haven't been able to find just the sensor and if I do need to change the entire throttle body how do I know which one to change?
Old Jul 5, 2016 | 07:49 AM
SonicVQ's Avatar
SonicVQ
P2135 is for bank 1, the passenger side throttle body and it must be replaced as a unit. (no parts/sensors are available separately)
If you know how to use a multi-meter you can use the factory shop manual is here: Index of /FSM/G37/Sedan/2011
Look at "EC.pdf" page 1031 to troubleshoot.
Old Jul 10, 2025 | 03:47 PM
Rudemark1's Avatar
Rudemark1
Not seeing a page 1031.
Hello sonic vq. I'm not seeing a pg 1031 on the nico site/PDF file for the EC. On my 2009 or 2011 g37. It on goes to pg 619.
Old Jul 11, 2025 | 09:43 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Some EC copies are divided in half with the first being "VQ37VHR for USA and Canada" while the second being "VQ37VHR for Mexico." Why the distinction I don't know.
Just look up your code in the index and go from there.
BillyTheMan
Jun 27, 2025 08:40 PM
Unicornvq
TSB - Technical Bulletins
Aug 13, 2024 08:38 AM
SlowG37s
General Tech Questions
Jan 19, 2022 06:17 PM
JakeG37
Apr 20, 2018 12:05 PM
blacky g37
Dec 22, 2010 07:47 PM
